C:\Program Files (x86)\GNU Tools ARM Embedded\8 2018-q4-major\bin\arm-none-eabi-ld.exe: c:/program files (x86)/gnu tools arm embedded/8 2018-q4-major/bin/../lib/gcc/arm-none- eabi/8.2.1/../../../../arm-none-eabi/lib/thumb/v7e-m+fp/hard/libstdc++.a(vterminate.o): in function '__gnu_cxx::__verbose_terminate_handler()': vterminate.cc:(.text._ZN9__gnu_cxx27__verbose_terminate_handlerEv+0xf4): undefined reference to '_impure_ptr' Memory region Used Size Region Size %age Used ram: 420408 B 1536 KB 26.73% make: *** [Makefile:230: build/firmware.elf] Error 1
I’m using a Windows 10 OS, running “MSYS2 MSYS” to compile the code.
NOTE: Makefile does not handle paths with spaces well (this will be patched soon) so ensure that the location where the firmware was cloned does not contain spaces (or special characters) otherwise " " variables in Makefile appropriately.
Then I build the application successfully (similarly like you):
make clean
CROSS_COMPILE=/c/Program\ Files\ \(x86\)/GNU\ Tools\ ARM\ Embedded/8\ 2018-q4-major/bin/arm-none-eabi- make -j
The code does build successfully at first. However, as soon as I add the raw data into the features[] variable in ei_main.cpp line 28 that matches with the size of the window from my edge impulse model as specified in the tutorial from
The code runs through the error I mentioned earlier. Any other size (or empty) the variable holds would maker the code successfully build, but fail to run through the classifier.
I confirmed that my PATH is the same and have compiled in the same way as you did using CROSS_COMPILE.
I also made sure that the paths don’t contain any spaces / special characters.
I tested the example standalone with raw features and it also successfully worked on my end. I’m wondering if the model we created is the problem. The project ID is 52615. Would you be able to check the example standalone with our project to make sure the error is occurring from the model and not the code? Thank you.
I’m able to reproduce the issue with your model and example-standalone-inferencing-spresense firmware.
I’ve yet to find a solution but a work-around is to decrease your window size < 2500 ms.
2500 ms at 16 kHz results in 40000 features in the feature array. This seems to cause this issue with the spresense build system. I don’t see this occuring with other standalone examples (e.g. example-standalone-inferencing or example-standalone-inferencing-ti-launchxl).
In the meantime will track this bug. I hope this helps.
