I have listed my code below and marked the error statements. It has undefined reference to ECG_Filter_initialize()' and undefined reference to ecg_analyzer(int)’. @aurel @louis
CODE:
#include <Arduino_LSM9DS1.h>
#include <ecg_analyzer_inference.h>
#include <ecg_analyzer.h>
//#include "C:/Users/ajayr/Documents/Arduino/libraries/EI_Deployed_Library/src/ecg_analyzer_inference.h"
//#include <Arduino_LSM9DS1.h>
//extern "C" {
//#include "C:/Users/ajayr/Documents/Arduino/libraries/ECGAnalyzer_lib/ecg_analyzer.h"
#define EI_CLASSIFIER_SENSOR 1
#define EIDSP_USE_CMSIS_DSP 1
#define EIDSP_LOAD_CMSIS_DSP_SOURCES 1
/*************************************OLED*********************************/
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for SSD1306 display connected using software SPI (default case):
#define OLED_MOSI 11
#define OLED_CLK 13
#define OLED_DC 9
#define OLED_CS 10
#define OLED_RESET 8
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
/* Comment out above, uncomment this block to use hardware SPI
#define OLED_DC 6
#define OLED_CS 7
&SPI, OLED_DC, OLED_RESET, OLED_CS);
#define NUMFLAKES 10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
static const unsigned char PROGMEM logo_bmp[] =
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x42, 0x42, 0x42, 0x42, 0x42, 0x02, 0x00, 0x00, 0x00, 0x00,
0xFE, 0x02, 0x02, 0x02, 0x04, 0x04, 0x08, 0xF0, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x0C, 0x04, 0x02,
0x02, 0x02, 0x82, 0x84, 0x80, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x42, 0x42, 0x42, 0x42, 0x42, 0x02,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFC, 0x38,
0x60, 0xC0, 0x80, 0x80, 0xC0, 0x30, 0x38, 0xFE, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x82, 0x82, 0x82,
0x82, 0x82, 0x84, 0x7C, 0x00, 0x00, 0x00, 0x00, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x00, 0x00, 0x00, 0x00,
0x0F, 0x08, 0x08, 0x08, 0x08, 0x0C, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x04, 0x08, 0x08,
0x08, 0x08, 0x08, 0x08, 0x07, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00,
0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x0C, 0x08, 0x08, 0x08, 0x08, 0x0C, 0x07,
/*********************************** Preidctions variable ***********************/
int NormalStateCounter = 0;
int AtrialFibrillationCounter = 0;
int First_DegreeHeartBlockCounter = 0;
int predictionCounter = 1;
const char *prediction;
float THRESHOLD_CYCLE_TIME = 60000;
bool OnecycleCheckEnable = 0;
float CycleCheckCounter = 0;
uint8_t NORMAL_STATE = 1;
uint8_t ATRIAL_FIBRILLATION_STATE = 2;
uint8_t FIRST_DEGREE_HEART_BLOCK_STATE = 3;
int MaximumOccuredEvent(int n1 , int n2, int n3);
uint8_t Event = 0;
float percentageCaln = 0;
static uint32_t run_inference_every_ms = 200;
static rtos::Thread inference_thread(osPriorityLow);
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = { 0 };
static float inference_buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
/* Forward declaration */
void run_inference_background();
@brief Arduino setup function
void setup()
Serial.begin(115200);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Clear the buffer
display.clearDisplay();
display.setTextSize(2); // Draw 2X-scale text
display.setTextColor(SSD1306_WHITE);
display.setCursor(10, 0);
display.println(F("ECG"));
display.display(); // Show initial text
display.println(F("ANALYZER"));
delay(3000);
// Clear the buffer
display.setTextSize(1); // Draw 2X-scale text
display.println(F("Powered by"));
display.println(F("Edge "));
display.println(F(" Impulse "));
display.println(F("Anna"));
display.println(F(" University"));
display.println(F("Project by: "));
display.println(F(" Ajay Raj B "));
display.println(F("Embedded "));
display.println(F(" Systems"));
display.println(F(" Technologies"));
delay(3000);
display.println(F("Analyzing..."));
//pinMode(10, INPUT); // Setup for leads off detection LO +
//pinMode(11, INPUT); // Setup for leads off detection LO -
**ECG_Filter_initialize();**
inference_thread.start(mbed::callback(&run_inference_background));
@brief Printf function uses vsnprintf and output using Arduino Serial
@param[in] format Variable argument list
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
@brief Run inferencing in the background.
// wait until we have a full buffer
delay((EI_CLASSIFIER_INTERVAL_MS * EI_CLASSIFIER_RAW_SAMPLE_COUNT) + 100);
// This is a structure that smoothens the output result
// With the default settings 70% of readings should be the same before classifying.
ei_classifier_smooth_t smooth;
ei_classifier_smooth_init(&smooth, 10 /* no. of readings */, 7 /* min. readings the same */, 0.8 /* min. confidence */, 0.3 /* max anomaly */);
while (1) {
// copy the buffer
memcpy(inference_buffer, buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE * sizeof(float));
signal_t signal;
int err = numpy::signal_from_buffer(inference_buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
// ei_printf("Predictions ");
//ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
// result.timing.dsp, result.timing.classification, result.timing.anomaly);
ei_printf(": ");
// ei_classifier_smooth_update yields the predicted label
const char *prediction = ei_classifier_smooth_update(&smooth, &result);
ei_printf("%s ", prediction);
if (strcmp(prediction, "uncertain") != 0)
predictionCounter++;
if (strcmp(prediction, "Normal") == 0)
NormalStateCounter++;
Serial.print("NormalStateCounter: \t");
Serial.println(NormalStateCounter);
else if (strcmp(prediction, "Atrial Fibrillation") == 0)
AtrialFibrillationCounter++;
Serial.print("AtrialFibrillationCounter: \t");
Serial.println(AtrialFibrillationCounter);
else if (strcmp(prediction, "First-Degree Heart Block") == 0)
First_DegreeHeartBlockCounter++;
Serial.print("First_DegreeHeartBlockCounter: \t");
Serial.println(First_DegreeHeartBlockCounter);
// print the cumulative results
ei_printf(" [ ");
for (size_t ix = 0; ix < smooth.count_size; ix++) {
ei_printf("%u", smooth.count[ix]);
if (ix != smooth.count_size + 1) {
ei_printf(", ");
else {
ei_printf(" ");
ei_printf("]\n");
delay(run_inference_every_ms);
ei_classifier_smooth_free(&smooth);
@brief Get data and run inferencing
@param[in] debug Get debug info if true
void loop()
while (1) {
while (1) {
if (OnecycleCheckEnable == 0)
CycleCheckCounter = millis();
OnecycleCheckEnable = 1;
// roll the buffer -3 points so we can overwrite the last one
numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -3);
**ecg_analyzer(analogRead(A0));**
Serial.print(calculated_ecg_values[0]);
Serial.print("\t");
Serial.print(calculated_ecg_values[1]);
Serial.print("\t");
Serial.println(calculated_ecg_values[2]);
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] = calculated_ecg_values[0];
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] = calculated_ecg_values[1];
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] = calculated_ecg_values[2];
// and wait for next tick
uint64_t time_to_wait = next_tick - micros();
delay((int)floor((float)time_to_wait / 1000.0f));
delayMicroseconds(time_to_wait % 1000);
if (millis() - CycleCheckCounter > THRESHOLD_CYCLE_TIME && (OnecycleCheckEnable == 1))
OnecycleCheckEnable = 0; //reset
percentageCaln = ((NormalStateCounter * 100) / predictionCounter);
display.print(F("Normal Rate: "));
display.setCursor(10, 10);
display.setTextSize(3); // Draw 2X-scale text
display.println(percentageCaln);
delay(3000);
percentageCaln = ((AtrialFibrillationCounter * 100) / predictionCounter);
display.print(F("AtrialFibrillation Rate : "));
display.setCursor(10, 25);
delay(3000);
percentageCaln = ((First_DegreeHeartBlockCounter * 100) / predictionCounter);
display.print(F("AV_Block 1: "));
display.setCursor(10, 12);
delay(3000);
Event = MaximumOccuredEvent(NormalStateCounter, AtrialFibrillationCounter, First_DegreeHeartBlockCounter);
switch (Event)
case 1:
Serial.print(" OUTPUT : NORMAL_STATE \t");
Serial.println(percentageCaln);
break;
case 2:
Serial.print(" OUTPUT : ATRIAL_FIBRILLATION_STATE \t");
display.print(F("AtrialFibrillation Rate: "));
break;
case 3:
Serial.print(" OUTPUT : FIRST_DEGREE_HEART_BLOCK_STATE \t");
display.print(F("First_DegreeHeartBlock Rate: "));
break;
default:
Serial.println("Uncertain");
break;
delay(1000);
//Reset counters for next cycle check
predictionCounter = 0;
int MaxEvent;
if (n1 >= n2) {
if (n1 >= n3)
MaxEvent = 1;
else
MaxEvent = 3;
} else {
if (n2 >= n3)
MaxEvent = 2;
else
MaxEvent = 3;
return MaxEvent;
void testdrawbitmap(void) {
display.drawBitmap(
(display.width() - LOGO_WIDTH ) / 2,
(display.height() - LOGO_HEIGHT) / 2,
logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
display.display();
delay(1000);
