After installing the dependencies (Edge Impulse CLI, Arduino CLI), I was unable to upload the edge impulse firmware to the Arduino board when I selected the flash_windows.bat. Instead, I received this message in the command prompt:
Can you verify your PATH environment variable? It should contain the Arduino CLI path. You can verify if it works by opening a terminal and run: arduino-cli
This is strange as the where command is part of Windows OS.
Does it work if you run: C:\Windows\System32\where
If it does work, can you check that your system environment variable contains this System32 directory?
However, seems like System32 directory is not available (can’t post the screenshot as only one screenshot is allowed (at least for new user, I presume)).
Incomplete installation, I guess. Which one, I wonder.
