I followed code copied from here.
from transformers import TFMobileViTForImageClassification
import tensorflow as tf
model_ckpt = "apple/mobilevit-xx-small"
model = TFMobileViTForImageClassification.from_pretrained(model_ckpt)
converter = tf.lite.TFLiteConverter.from_keras_model(model)
converter.optimizations = [tf.lite.Optimize.DEFAULT]
converter.target_spec.supported_ops = [
tf.lite.OpsSet.TFLITE_BUILTINS,
tf.lite.OpsSet.SELECT_TF_OPS,
tflite_model = converter.convert()
tflite_filename = model_ckpt.split("/")[-1] + ".tflite"
with open(tflite_filename, "wb") as f:
f.write(tflite_model)
After saving .tflite file, I run the following in Colab.
ei.model.profile(model='./mobilevit-xx-small.tflite')
But I got this.
Exception Traceback (most recent call last)
<ipython-input-13-1bfe319f0780> in <cell line: 1>()
----> 1 ei.model.profile(model='./mobilevit-xx-small.tflite')
12 frames
/usr/local/lib/python3.10/dist-packages/edgeimpulse_api/api_client.py in deserialize(self, response, response_type)
304
305 if not data["success"]:
--> 306 raise Exception(data["error"])
307
308 except ValueError:
Exception: No uploaded model yet
This often means that the model you are attempting to upload is unsupported.
But I don’t think this is the case. (Doc said TensorFlow Lite (.tflite or .lite) is supported)
