Question/Issue: Unable to install edge impulse on M1 macbook air macos Ventura using terminal
**Project ID:**169159 project ID
Context/Use case: Error in terminal
npm WARN using --force Recommended protections disabled.
npm ERR! code EACCES
npm ERR! syscall mkdir
npm ERR! path /usr/local/lib/node_modules/edge-impulse-cli
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/edge-impulse-cli’
npm ERR! [Error: EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/edge-impulse-cli’] {
npm ERR! errno: -13,
npm ERR! code: ‘EACCES’,
npm ERR! syscall: ‘mkdir’,
npm ERR! path: ‘/usr/local/lib/node_modules/edge-impulse-cli’
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
