When I run the spectral feature generation on data on edge impulse I get the following error
Creating windows from 27 files...
[ 1/27] Creating windows from files...
[27/27] Creating windows from files...
Created 81 windows: M: 42, O: 39
Scheduling job in cluster...
Job started
Creating features
[ 1/81] Creating features...
[81/81] Creating features...
Created features
Attached to job 188264...
No data received from server for 30 seconds...
Job failed (see above)
Kindly advise
Interesting, that looks like a finished job to me. It seems that the job finished faster than the log attachment came through. You can see the feature explorer right? If that’s the case then the job ran successful anyway.
I cant see the any features or graph in the feature explorer
No features generated yet.
What’s your project ID? I’ll take a look.
Hi When I run again I get the following error
Creating job...
Failed to create job: Cannot start job. There already is a job with key "dsp-2" running.
My Project is vibDemoFieldDevice
Creating job... OK (ID: 188272)
Not generating new features: features already generated and no options or files have changed.
Job completed
So this is what I see. I think this might be related to the distance to the data center, if the job finishes sometimes the last job messages don’t come through…
@janjongboom
Thank you for logging into my project for support. I see that when I increase the window size from 2800ms that you set to 4000ms, It now shows that necessary frames are not there. Can you share how the calculation of window size is done so that Spectral Features can be generated?
@paulphilip your items in the dataset are 3 seconds long, so your window should be less than that; otherwise you’ll get these errors indeed.
@janjongboom Please excuse that I got the project wrong. It is TESTDATAUPLOAD and the data length is 5s. The errors mentioned above is for the project above.
Interesting. I’ve killed the job for you now, and will make something where you won’t get stuck.
@mathijs could you look at the logs to see why this job was not marked as finished? Job ID 188264.
@janjongboom @mathijs
Hi I was trying to build the model for project 5392 but it is not getting scheduled for build
Still waiting for job to be scheduled...
Job did not start within 60 seconds
Received cancellation, stopping job in cluster...
Attached to job 255795...
When I rerun again I get the following error.
Failed to create job: Cannot start job. There already is a job with key "dsp-3" running.
Kindly advise on how to avoid this problem.
/cc @Hardik
Hi I used the cancel job api to cancel the job and reschedule it once again. I am unable to do it. Kindly advise.
Creating job... OK (ID: 255797)
Retraining Spectral features...
No data received from server for 60 seconds...
/cc @Hardik
Hi @paulphilip, we had an outage this morning (events to/from job containers were not routed), this has now been resolved!
Hi @janjongboom
I was able to build the model. Now I am facing a new error when I am trying to run the model to classify on a test data.
Please advise.
/cc @Hardik
Hi, we rolled out a change to prevent samples with a different frequency to be classified (to avoid mixing frequencies), but apparently there is some rounding differences involved when calculating the frequency. Will push out a fix today.
@paulphilip @Hardik this has now been rolled out!
There are 3 features as you can see.
Error in feature generation -
Feature generation output
Creating job… OK (ID: 1100410)
Scheduling job in cluster…
Creating windows from 1 files…
Job started
[0/1] Creating windows from files…
[1/1] Creating windows from files…
Created 14939 windows: standing_test: 14939
Creating features
[ 1/14939] Creating features…
[14939/14939] Creating features…
Created features
Job started
Reducing dimensions for visualizations…
ERR: Found array with 0 feature(s) (shape=(2000, 0)) while a minimum of 1 is required.
Hi @Lakshmi I looked at your project (39100) but I think you removed the data.
Ok I can add the data and then you can take a look at it
