Two output regression model
Hi Team,
i need help on multi output regression model. so here i have X co-ordinate and Y co-ordinate data as inputs and i wanted to get two output regression model.
  1. How can i feed the inputs to edge impulse
    ------for x-co-ordinate, how can i feed and also y-co-ordinate?
  2. if any chance to get multi output with regression, what is the procedure? or any way to get it done?
Thanks and Regards,
—JD
#multi-output with regression
#edgeimpulse
Hello @jdandu first of all welcome to the Edge Impulse community!
Let me try to reply your questions below :point_down:
Did you try uploading a CSV file? You can have a CSV file with 3 columns (or 2): timestamp, X and Y columns. Then you can use the CSV wizard. If you don’t have timestamp, that’s fine.
My initial recommendation to get a multi output with regression would be to create your own Custom Learning Block → Custom learning blocks - Edge Impulse Documentation
Another creative idea, is that you can train 2 models, one that giving X,Y predicts X, and another that giving X, Y predicts Y.
But I think it’s better if you create your own custom learning block.
Let us know if you have any questions!
Happy to help you here :slight_smile:
