I’m a bit of a node/npm noob. I’m trying to install edge-impulse-cli on Mac OS and I’m getting this:
/usr/local/bin/edge-impulse-uploader -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/uploader.js
/usr/local/bin/edge-impulse-blocks -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/blocks.js
/usr/local/bin/edge-impulse-daemon -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/daemon.js
/usr/local/bin/edge-impulse-data-forwarder -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/data-forwarder.js
/usr/local/bin/eta-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/eta-flash-tool/flashtool.js
/usr/local/bin/edge-impulse-run-impulse -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/run-impulse.js
/usr/local/bin/edge-impulse-framebuffer2jpg -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/framebuffer-to-jpg.js
/usr/local/bin/himax-flash-tool -> /usr/local/lib/node_modules/edge-impulse-cli/build/cli/himax-flash-tool/flashtool.js
@serialport/bindings@8.0.8 install /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install self signed certificate in certificate chain
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: self signed certificate in certificate chain
gyp ERR! stack at TLSSocket.onConnectSecure (_tls_wrap.js:1497:34)
gyp ERR! stack at TLSSocket.emit (events.js:315:20)
gyp ERR! stack at TLSSocket._finishInit (_tls_wrap.js:932:8)
gyp ERR! stack at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:706:12)
gyp ERR! System Darwin 19.6.0
gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
gyp ERR! cwd /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install: prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /Users/x/.npm/_logs/2021-03-29T20_56_03_529Z-debug.log
I already set strict-ssl in npm to false.
This is in preparation for upcoming class on April 1.
Please help! Thank you!
