“Failed to initialize linux tool First photo was not created within 20 seconds” this shows up when i run edge-impulse-linux on my raspberry pi. please tell me how to fix it
Which model of Raspberry Pi and camera are you using?
Can you run again the command edge-impulse-linux --clean and provide the logs?
Finally, can you check if you have an edge-impulse-cli... directory under /tmp?
