Question/Issue: I have problem understanding code, especially regarding buffer size.
Project ID: 213088
While reading code in examples/esp32/esp32_microphone_continuous/esp32_microphone_continuous.ino
, I had following thoughts.
static void audio_inference_callback(uint32_t n_bytes)
for(int i = 0; i < n_bytes>>1; i++) {
inference.buffers[inference.buf_select][inference.buf_count++] = sampleBuffer[I];
Here, considering that we are dealing with 16bits(2 bytes) per sample(configured in i2s_config), n_bytes>>1
is understandable for now.
is called in capture_samples
with i2s_bytes_to_read
, and i2s_bytes_to_read
is same as arg
static void capture_samples(void* arg) {
const int32_t i2s_bytes_to_read = (uint32_t)arg;
size_t bytes_read = i2s_bytes_to_read;
if (record_status) {
audio_inference_callback(i2s_bytes_to_read);
And, capture_samples
is called with sample_buffer_size
, which is 2048.
xTaskCreate(capture_samples, "CaptureSamples", 1024 * 32, (void*)sample_buffer_size, 10, NULL);
- So,
i2s_bytes_to_read
is 2048 (=sample_buffer_size)
// static void capture_samples(void* arg)
for (int x = 0; x < i2s_bytes_to_read/2; x++) {
sampleBuffer[x] = (int16_t)(sampleBuffer[x]) * 8;
But here, why /2
? It seems we are iterating half of the buffer.
Also here. audio_inference_callback
is called with 2048
and sampleBuffer
size is also 2048. So it seems like we are interacting half of buffer here too.
Is there something that I am missing?
Thank you for your help.
