Transfer learning locally using ipython notebook: error in weight path
I’m trying to train the model locally by using ipython notebook downloaded from the project. But i’m facing an error in the weights path.
ValueError Traceback (most recent call last)
C:\Users\MLTEAM~1\AppData\Local\Temp/ipykernel_8328/2519843456.py in
12 INPUT_SHAPE = (32, 32, 3)
13
—> 14 base_model = tf.keras.applications.MobileNetV2(
15 input_shape = INPUT_SHAPE, alpha=0.35,
16 weights = WEIGHTS_PATH
C:\Program Files\Python39\lib\site-packages\keras\applications\mobilenet_v2.py in MobileNetV2(input_shape, alpha, include_top, weights, input_tensor, pooling, classes, classifier_activation, **kwargs)
190 raise ValueError(f’Unknown argument(s): {kwargs}’)
191 if not (weights in {‘imagenet’, None} or tf.io.gfile.exists(weights)):
–> 192 raise ValueError('The weights argument should be either ’
193 ’None (random initialization), imagenet ’
194 '(pre-training on ImageNet), ’
ValueError: The weights argument should be either None (random initialization), imagenet (pre-training on ImageNet), or the path to the weights file to be loaded. Received `weights=./transfer-learning-weights/keras/mobilenet_v2_weights_tf_dim_ordering_tf_kernels_0.35_96.h5
Weights path is mentioned as below
WEIGHTS_PATH = './transfer-learning-weights/keras/mobilenet_v2_weights_tf_dim_ordering_tf_kernels_0.35_96.h5'
I understand that the weights file is not present locally. Is there any way to download that weights file from edge impulse?
Thanks and Regards,
Ramson Jehu K
Hello @Ramson,
You can download the weights from this url: https://cdn.edgeimpulse.com/transfer-learning-weights/keras/mobilenet_v2_weights_tf_dim_ordering_tf_kernels_0.35_96.h5
See also @janjongboom comment’s on this thread if you want to download other weights from different models: Keras pretrain weight
hello louis,
Thank you so much for the url. that solved my issue.
But Now i’m facing a different issue with the data augmentation.
ValueError: in user code:
File "C:\Users\MLTEAM~1\AppData\Local\Temp/ipykernel_2912/2041261749.py", line 41, in augment_image  *
        image = tf.image.random_flip_left_right(image)
ValueError: 'image' (shape (3072,)) must be at least three-dimensional.
This is the code snippet im running
import math
from pathlib import Path
import tensorflow as tf
from tensorflow.keras import Model
from tensorflow.keras.models import Sequential
from tensorflow.keras.layers import Dense, InputLayer, Dropout, Conv1D, Flatten, Reshape, MaxPooling1D, BatchNormalization, Conv2D, GlobalMaxPooling2D, Lambda
from tensorflow.keras.optimizers import Adam, Adadelta
from tensorflow.keras.losses import categorical_crossentropy
WEIGHTS_PATH = 'mobilenet_v2_weights_tf_dim_ordering_tf_kernels_0.35_96.h5'
base_model.trainable = False
model = Sequential()
model.add(InputLayer(input_shape=INPUT_SHAPE, name='x_input'))
# Don't include the base model's top layers
last_layer_index = -3
model.add(Model(inputs=base_model.inputs, outputs=base_model.layers[last_layer_index].output))
model.add(Dense(16, activation='relu'))
model.add(Dropout(0.1))
model.add(Flatten())
model.add(Dense(classes, activation='softmax'))
model.compile(optimizer=tf.keras.optimizers.Adam(learning_rate=0.0005),
                loss='categorical_crossentropy',
                metrics=['accuracy'])
# Implements the data augmentation policy
def augment_image(image, label):
    # Flips the image randomly
    # Increase the image size, then randomly crop it down to
    # the original dimensions
    resize_factor = random.uniform(1, 1.2)
    new_height = math.floor(resize_factor * INPUT_SHAPE[0])
    new_width = math.floor(resize_factor * INPUT_SHAPE[1])
    image = tf.image.resize_with_crop_or_pad(image, new_height, new_width)
    image = tf.image.random_crop(image, size=INPUT_SHAPE)
    # Vary the brightness of the image
    image = tf.image.random_brightness(image, max_delta=0.2)
    return image, label
train_dataset = train_dataset.map(augment_image, tf.data.experimental.AUTOTUNE)
BATCH_SIZE = 32
train_dataset = train_dataset.batch(BATCH_SIZE, drop_remainder=False)
validation_dataset = validation_dataset.batch(BATCH_SIZE, drop_remainder=False)
model.fit(train_dataset, validation_data=validation_dataset, epochs=20, verbose=2, callbacks=callbacks)
print('')
print('Initial training done.', flush=True)
# How many epochs we will fine tune the model
FINE_TUNE_EPOCHS = 10
# What percentage of the base model's layers we will fine tune
FINE_TUNE_PERCENTAGE = 65
print('Fine-tuning best model for {} epochs...'.format(FINE_TUNE_EPOCHS), flush=True)
# Determine which layer to begin fine tuning at
model_layer_count = len(model.layers)
fine_tune_from = math.ceil(model_layer_count * ((100 - FINE_TUNE_PERCENTAGE) / 100))
# Allow the entire base model to be trained
model.trainable = True
# Freeze all the layers before the 'fine_tune_from' layer
for layer in model.layers[:fine_tune_from]:
    layer.trainable = False
model.compile(optimizer=tf.keras.optimizers.Adam(learning_rate=0.000045),
                epochs=FINE_TUNE_EPOCHS,
                verbose=2,
                callbacks=callbacks,
                class_weight=None
I guess it has something to do with reshape. But im not sure what to do. Please guide
Thanks and Regards,
Ramson Jehu K
Just an update on the last comment.
I reshaped the training and test dataset from 2d to 4d which kinda worked out for me.
X_train = X_train.reshape(X_train.shape[0],32,32,3)
X_test = X_test.reshape(X_test.shape[0],32,32,3)
Thanks,
Ramson Jehu K
Hello @Ramson,
Thanks for letting the community know how you fixed your issue.
