How do I do?
我想训练一个识别口罩的模型。我收集并分类好了一些数据集,创建了impulse,但是在迁移学习这里失败了。请问有谁可以帮我解决这个问题吗?谢谢!
Hello @Lincess,
It looks like you are trying to use a 48-pixels square images in Grayscale [48,48,1], while your input features seems to expect a 48-pixels square images in RGB (48 * 48 * 3 = 6912),
Could you try to generate again your features (under the images tab, click on save parameters and then generate features).
Thank you for your help,Louis!Best wishes!
Another suggestion would be to remove / re-add the transfer learning block from Create impulse. It should fix the dimensions.
