When starting training of my Neural Network it is reporting the following error:
Creating job... OK (ID: 219285)
Copying features from processing blocks...
Scheduling job in cluster...
Job started
Splitting data into training and validation sets...
Training model...
Training on 184 inputs, validating on 46 inputs
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/framework/ops.py", line 1654, in _create_c_op
c_op = pywrap_tf_session.TF_FinishOperation(op_desc)
tensorflow.python.framework.errors_impl.InvalidArgumentError: Negative dimension size caused by subtracting 5 from 4 for '{{node conv1d/conv1d}} = Conv2D[T=DT_FLOAT, data_format="NHWC", dilations=[1, 1, 1, 1], explicit_paddings=[], padding="VALID", strides=[1, 1, 1, 1], use_cudnn_on_gpu=true](conv1d/conv1d/ExpandDims, conv1d/conv1d/ExpandDims_1)' with input shapes: [?,1,4,13], [1,5,13,30].
File "/home/train.py", line 459, in <module>
main_function()
File "/home/train.py", line 396, in main_function
X_train, X_test, Y_train, Y_test, len(X_train), classes)
File "/home/train.py", line 44, in train_model
model.add(Conv1D(30, kernel_size=5, activation='relu'))
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/training/tracking/base.py", line 456, in _method_wrapper
result = method(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/sequential.py", line 213, in add
output_tensor = layer(self.outputs[0])
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/base_layer.py", line 922, in __call__
outputs = call_fn(cast_inputs, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/layers/convolutional.py", line 207, in call
outputs = self._convolution_op(inputs, self.kernel)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/ops/nn_ops.py", line 1106, in __call__
return self.conv_op(inp, filter)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/ops/nn_ops.py", line 638, in __call__
return self.call(inp, filter)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/ops/nn_ops.py", line 237, in __call__
name=self.name)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/ops/nn_ops.py", line 226, in _conv1d
name=name)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/util/deprecation.py", line 574, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/ops/nn_ops.py", line 1663, in conv1d
name=name)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/ops/gen_nn_ops.py", line 969, in conv2d
data_format=data_format, dilations=dilations, name=name)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/framework/op_def_library.py", line 744, in _apply_op_helper
attrs=attr_protos, op_def=op_def)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/framework/func_graph.py", line 595, in _create_op_internal
compute_device)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/framework/ops.py", line 3327, in _create_op_internal
op_def=op_def)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/framework/ops.py", line 1817, in __init__
control_input_ops, op_def)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/framework/ops.py", line 1657, in _create_c_op
raise ValueError(str(e))
ValueError: Negative dimension size caused by subtracting 5 from 4 for '{{node conv1d/conv1d}} = Conv2D[T=DT_FLOAT, data_format="NHWC", dilations=[1, 1, 1, 1], explicit_paddings=[], padding="VALID", strides=[1, 1, 1, 1], use_cudnn_on_gpu=true](conv1d/conv1d/ExpandDims, conv1d/conv1d/ExpandDims_1)' with input shapes: [?,1,4,13], [1,5,13,30].
Job failed (see above)
Here a screenshot of the same error:
Here a screenshot of the generated features (MFCC) that are used as input for the neural network:
