In the learning block, I selected classification. In this section, I don’t know why I could not train my model.
What is the problem?
Creating job… OK (ID: 7785258)
Scheduling job in cluster…
Job started
Container image pulled!
Job started
Training model…
Training on 308 inputs, validating on 78 inputs
File “/home/train.py”, line 262, in
main_function()
File “/home/train.py”, line 190, in main_function
model, override_mode, disable_per_channel_quantization, akida_model, akida_edge_model = train_model(train_dataset, validation_dataset,
File “/home/train.py”, line 135, in train_model
model.fit(train_dataset, epochs=EPOCHS, validation_data=validation_dataset, verbose=2, callbacks=callbacks, class_weight=ei_tensorflow.training.get_class_weights(Y_train))
File “/app/keras/.venv/lib/python3.8/site-packages/keras/utils/traceback_utils.py”, line 67, in error_handler
raise e.with_traceback(filtered_tb) from None
File “/app/keras/.venv/lib/python3.8/site-packages/keras/engine/data_adapter.py”, line 1426, in _make_class_weight_map_fn
raise ValueError(error_msg)
ValueError: Expected class_weight to be a dict with keys from 0 to one less than the number of classes, found {3: 0.3117408906882591, 2: 12.833333333333334, 1: 1.4528301886792452, 4: 38.5}
Hi @nwaso886,
When I checked your project, it looks like you were able to get the model to train. Is it working for you now?
I started my first project( 643751) as a Object Detection model and it was getting good results. I then removed the object recognition module and replace it with “Transfer learning” as I saw that in the tutorial and classification is actually what I’m after. I re-labeled all my images to have one label per rather than frames (after getting a helpful learning error that told me the labels were wrong).
I now get this error with training. I understand that I have a very small population per classification to train on and will acquire more images but I don’t think that’s the specific issue.
Any tips on fault-finding for this error?
I added more data to ensure there were at least 2 training, 1 validation and 1 testing image. This didn’t fix the issues.
However, I then changed the engine for the model. I think it was still using a object detection method rather than a classification method. Changing this enabled me to train the model.
When i change the project from object detection to classification, it didn’t update the AI structure and I think an incompatible component was still in the transfer block.
I hope this helps others :). I’m back on track now - just need to create a LOT more training images.
