Train v Test during options upload not remembering user selection
Question/Issue: I have 5000 images samples. Half of them are in test and the others are in train folders respectively. When I pre-select “Testing” or “Training” from the following list:
Upload into category
Automatically split between training and testing
Training
Testing
the uploader just splits them anyways. I need to be able to upload them separately. Fixing with multi select only works once. When I upload the second half (“test”) to the dataset explorer, it puts most f them in the “train” category.
Additionally I am asking it to detect labels from filenames and this is not working. What do I need to do, or what are these options presented for?
Hello @alloydylan,
You have several options to upload your files and add them to either the training or testing dataset:
You can also import a info.labels file where you can specify in which dataset your want to add your data samples and your labels: https://docs.edgeimpulse.com/docs/edge-impulse-studio/data-acquisition/uploader#edge-impulse-exporter-format-info.labels-files
To automatically detect labels from your filename, your samples need to have names like the following:
label.whatever-id.extension.
E.g
  • rhinoceros.3456.jpg will set the label rhino for your image.
  • rose.abcd.png will set the label rose
When using the datasources, you can also use the folder name as a label see Data sources | Edge Impulse Documentation.
