- Copyright (c) 2022 EdgeImpulse Inc.
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the “Software”), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
#include <GreatoR-project-1_inferencing.h>
#include “edge-impulse-sdk/dsp/image/image.hpp”
#include <PID_v1.h>
#include “esp_camera.h”
#include <ESP32Servo.h>
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
Servo panServo;
Servo tiltServo;
// Define PID parameters
double kp = 1.0;
double ki = 0.0;
double kd = 0.0;
double panInput, panOutput, panSetpoint;
double tiltInput, tiltOutput, tiltSetpoint;
// Define PID objects
PID panPID(&panInput, &panOutput, &panSetpoint, kp, ki, kd, DIRECT);
PID tiltPID(&tiltInput, &tiltOutput, &tiltSetpoint, kp, ki, kd, DIRECT);
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 4
#define SIOD_GPIO_NUM 18
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 36
#define Y8_GPIO_NUM 37
#define Y7_GPIO_NUM 38
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 35
#define Y4_GPIO_NUM 14
#define Y3_GPIO_NUM 13
#define Y2_GPIO_NUM 34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM 27
#define PCLK_GPIO_NUM 25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#else
#error “Camera model not selected”
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
.xclk_freq_hz = 20000000,
.ledc_timer = LEDC_TIMER_0,
.frame_size = FRAMESIZE_QVGA, //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
.fb_count = 1, //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
@brief Arduino setup function
void setup()
// Initialize PID objects
panPID.SetMode(AUTOMATIC);
tiltPID.SetMode(AUTOMATIC);
Serial.begin(115200);
while (!Serial);
Serial.println(“Edge Impulse Inferencing Demo”);
ei_printf(“Failed to initialize Camera!\r\n”);
else {
ei_printf(“Camera initialized\r\n”);
ei_printf(“\nStarting continious inference in 2 seconds…\n”);
ei_sleep(2000);
@brief Get data and run inferencing
@param[in] debug Get debug info if true
void loop()
// instead of wait_ms, we’ll wait on the signal, this allows threads to cancel us…
return;
if(snapshot_buf == nullptr) {
ei_printf(“ERR: Failed to allocate snapshot buffer!\n”);
return;
ei::signal_t signal;
ei_printf(“Failed to capture image\r\n”);
free(snapshot_buf);
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
ei_printf(“ERR: Failed to run classifier (%d)\n”, err);
return;
// print the predictions
ei_printf(“Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n”,
if (bb.value == 0) {
continue;
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
// Update PID setpoints based on object position
panSetpoint = map(bb.x + bb.width / 2, 0, EI_CAMERA_RAW_FRAME_BUFFER_COLS, 0, 180);
tiltSetpoint = map(bb.y + bb.height / 2, 0, EI_CAMERA_RAW_FRAME_BUFFER_ROWS, 0, 180);
// Compute PID outputs
panPID.Compute();
tiltPID.Compute();
// Set servo positions based on PID outputs
// (Assuming you have already initialized the servo motors)
panServo.write(panOutput);
tiltServo.write(tiltOutput);
if (!bb_found) {
ei_printf(" No objects found\n");
#else
ei_printf(" %s: %.5f\n", result.classification[ix].label,
#endif
#endif
free(snapshot_buf);
@brief Setup image sensor & start streaming
@retval false if initialisation failed
bool ei_camera_init(void) {
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
//initialize the camera
if (err != ESP_OK) {
return false;
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
s->set_vflip(s, 1);
s->set_awb_gain(s, 1);
#endif
is_initialised = true;
return true;
@brief Stop streaming of sensor data
void ei_camera_deinit(void) {
//deinitialize the camera
if (err != ESP_OK)
ei_printf(“Camera deinit failed\n”);
return;
return;
bool do_resize = false;
if (!is_initialised) {
return false;
if (!fb) {
return false;
esp_camera_fb_return(fb);
if(!converted){
ei_printf(“Conversion failed\n”);
return false;
do_resize = true;
if (do_resize) {
out_buf,
out_buf,
img_width,
img_height);
return true;
size_t pixel_ix = offset * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
// go to the next pixel
out_ptr_ix++;
pixel_ix+=3;
pixels_left--;
// and done!
return 0;
#error “Invalid model for current sensor”
#endif
