I am building for an Arduino Portenta.
Is EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16 the Sample Length in milliseconds on the Arduino?
If so shouldn’t this value be equal to Window Size in the Time Series Data block of the Impulse design.
Hi @MMarcial,
EI_CLASSIFIER_RAW_SAMPLE_COUNT is equal to the number of sample frames expected by the DSP block, which is not the same as the window size. See this API reference for more info: model_metadata.h - Edge Impulse API. I hope that helps!
The link helped.
I should have paid attention to units, aka, EI_CLASSIFIER_RAW_SAMPLE_COUNT is a unitless value and Window Size has units of seconds.
In summary:
Window Size [s] is directly proportional to EI_CLASSIFIER_RAW_SAMPLE_COUNT.Window Size [s] = EI_CLASSIFIER_RAW_SAMPLE_COUNT / Sampling Rate [hz]
