TI AM62A Cannot find any webcams
I’m using a detected USB webcam (which works ok with the other TI, TDA4VM)
USB Camera 0 detected
device = /dev/video-usb-cam0
format = jpeg
root@am62axx-evm:/opt/edgeai-gst-apps# lsusb
Bus 001 Device 002: ID 1b3f:2247 Generalplus Technology Inc. GENERAL WEBCAM
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
But when I run
edge-impulse-linux
Failed to initialize linux tool Error: Cannot find any webcams, run this command with --disable-camera to skip selection
at /usr/lib/node_modules/edge-impulse-linux/build/cli/linux/linux.js:437:23
Do I need to add something to name_overlays= inside /run/media/BOOT-mmcblk1p1/uEnv.txt?
Or will a Raspberry Pi Cam connected to the J20 Flex work?
Hi there.
The USB camera works with TI examples, so it is compatible with AM62A but it is not detected by edge-impulse-linux-runner
I did also try CSI Rpi Cam imx219 adding this overlay to /run/media/BOOT-mmcblk1p1/uEnv.txt but it did not work
name_overlays=k3-am62a7-sk-csi2-imx219.dtbo
Any advice? Thanks
I was using PSDK 09.00.01.03
I burned 08.06.00.45 and now the USB cam is working.
Hi @Bandini
Thank you for troubleshooting. Can you share the nodejs and our linux runner version numbers?
edge-impulse-linux-runner -V
node --version
Strange it works on earlier versions, hopefully you have an environmental issue.
@jbuckEI @rjames fyi
Hi Eoin,
For the working installation with SDK 08.06.00.45
edge-impulse-linux-runner 1.4.7
Node v12.22.12
I no longer have the microSD with PSDK 09.00.01.03 installed to check there.
Thanks @Bandini ,
@jbuckEI is aware and will investigate your issue. We will log an internal bug if he too fails to find the camera.
Thanks Eoin.
One more question: are these engine and target correct for AM62A?
edge-impulse-linux-runner --force-engine tidl --force-target runner-linux-aarch64-am62a
Hi @Bandini,
PSDK 9.0 made changes which affect/break the way we start the webcam.
We currently working on adding support for PSDK 9.0. For now use PSDK 08.06.00.45.
// Raul
Thanks for the answer, Raul.
