From https://docs.edgeimpulse.com/docs/silabs-thunderboard-sense-2, I stuck at here, I can not find the storage device, even I use simplicity commander to flash the bin file, It doesn’t work.
I am using windows.
I can see it in the simplicity studio
Hi @chelalv
Can you try re-flashing the SiLabs bootloader following the instructions here?: https://community.silabs.com/s/article/bootloader-mode-in-thunderboard-kits-and-how-to-fix-it?language=en_US
And then try flashing the firmware you downloaded from the Edge Impulse documentation here: https://docs.edgeimpulse.com/docs/silabs-thunderboard-sense-2
@chelalv You can flash through Simplicity Studio as well, right click on device => Flash => locate the .bin file.
so do I need to flash silabs bootloader? or just flash .silabs-thunderboard-sense2.bin file? what is the flash start address?
sorry, I think I have made a mistake, I took thunder board BG22 as thunder board sense2.
it works fine now, thanks for your support. you can mark this as answered
