The Code to Setup Arducam OV2640 with Rasberry pi pico as a Sensor
Hello, does anyone know how to do the code to set up Arducam’s ov2640 camera as a sensor and get its sensor data for the rasberry pi pico? I need it to classify data in real time instead of static. The code that I’ve based on is this github link :
https://github.com/ArduCAM/RPI-Pico-Cam
I can’t figure it out. Please help.
Classify and detect two image classes with live arducam ov2640 camera sensor with rasberry pi pico
Hello @Boratron,
Unfortunately, the Raspberry Pi Pico won’t be able to run an image classification model. It only has a Cortex-M0+
Really? But I was able to run an image classification model on my Pico. I copied the raw image features in my test set in edge impulse, then pasted it on the features array and then it ran. The predictions were displayed on the arduino serial monitor.
Oh!
Alright, I actually have not tried it myself. It probably has to do with the 256KB of RAM available on that board then. Just out of curiosity. What is the classification time?
I definitely need to buy one of those RPi Pico board to try it out myself.
From what I saw in this screenshot (from your link)
It seems that you can get the RGB565 (from the top line comment), pass all the RGB565 pixels into the “features” buffer, and then run the classifier as you do with the static buffer example.
Make sure your image size is the same as the one used for the training.
Thank you for replying! I’ll try out what you said.
For the classification time, here’s a screenshot from the arduino serial monitor on just using static data. Is this what you mean by classification time?
or this one?
Hello, can anyone help me on this. I am still trying to connect the ov2640 arducam to the Pico to get live data. I can’t seem to connect the port, like the port won’t show on the arduino serial monitor. It works just fine without the arducam library but when i added the library it does this. Here is the screenshot:
I’ve based the arducam library and how to set it up with the Pico in this github link: RPI-Pico-Cam/tflmicro at master · ArduCAM/RPI-Pico-Cam · GitHub
Here is my main.cpp in source/main.cpp:
#include "ei_run_classifier.h"
// #include "hardware/gpio.h"
// #include "hardware/uart.h"
// #include "pico/stdio_usb.h"
#include "pico/stdlib.h"
#ifdef __cplusplus
extern "C"
  #include "arducam.h"
#endif
#include <stdio.h>
const uint LED_PIN = 25;
    // copy raw features here (for example from the 'Live classification' page)
#ifndef DO_NOT_OUTPUT_TO_UART
// RX interrupt handler
void on_uart_rx() {
    uint8_t cameraCommand = 0;
    while (uart_is_readable(UART_ID)) {
        cameraCommand = uart_getc(UART_ID);
        // Can we send it back?
        if (uart_is_writable(UART_ID)) {
            uart_putc(UART_ID, cameraCommand);
void setup_uart() {
  // Set up our UART with the required speed.
  uint baud = uart_init(UART_ID, BAUD_RATE);
  // Set the TX and RX pins by using the function select on the GPIO
  // Set datasheet for more information on function select
  gpio_set_function(UART_TX_PIN, GPIO_FUNC_UART);
  gpio_set_function(UART_RX_PIN, GPIO_FUNC_UART);
  // Set our data format
  uart_set_format(UART_ID, DATA_BITS, STOP_BITS, PARITY);
  // Turn off FIFO's - we want to do this character by character
  uart_set_fifo_enabled(UART_ID, false);
  // Set up a RX interrupt
  // We need to set up the handler first
  // Select correct interrupt for the UART we are using
  int UART_IRQ = UART_ID == uart0 ? UART0_IRQ : UART1_IRQ;
  // And set up and enable the interrupt handlers
  irq_set_exclusive_handler(UART_IRQ, on_uart_rx);
  irq_set_enabled(UART_IRQ, true);
  // Now enable the UART to send interrupts - RX only
  uart_set_irq_enables(UART_ID, true, false);
#else
void setup_uart() {}
#endif
int raw_feature_get_data(size_t offset, size_t length, float *out_ptr)
  ei_printf("Gathering data \n");
  printf("All Good \n");
  return 0;
int main()
  // stdio_usb_init();
  setup_uart();
  // stdio_init_all();
  gpio_init(LED_PIN);
  gpio_set_dir(LED_PIN, GPIO_OUT);
  // arducam.systemInit();
  printf("pass");
  // if (arducam.busDetect())
  //   return 1;
  // if (arducam.cameraProbe())
  //   return 1;
  // arducam.cameraInit(YUV);
  ei_impulse_result_t result = {nullptr};
  while (true)
    ei_printf("Edge Impulse standalone inferencing (Raspberry Pi Pico)\n");
    if (sizeof(features) / sizeof(float) != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE)
      ei_printf("The size of your 'features' array is not correct. Expected %d items, but had %u\n",
      return 1;
    while (1)
      // blink LED
      gpio_put(LED_PIN, !gpio_get(LED_PIN));
      // the features are stored into flash, and we don't want to load everything into RAM
      signal_t features_signal;
      // invoke the impulse
      EI_IMPULSE_ERROR res = run_classifier(&features_signal, &result, false);
      if (res != 0)
        return 1;
      // print the predictions
      ei_printf("[");
      for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++)
        ei_printf("%.5f", result.classification[ix].value);
        ei_printf(", ");
#else
        if (ix != EI_CLASSIFIER_LABEL_COUNT - 1)
          ei_printf(", ");
#endif
      printf("%.3f", result.anomaly);
#endif
      printf("]\n");
      // human-readable predictions
          ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
      ei_sleep(2000);
Here is my CMakeLists.txt in root:
cmake_minimum_required(VERSION 3.13.1)
set(MODEL_FOLDER .)
set(EI_SDK_FOLDER edge-impulse-sdk)
include(pico_sdk_import.cmake)
project(pico_paper_detection C CXX ASM)
set(CMAKE_C_STANDARD 11)
set(CMAKE_CXX_STANDARD 11)
pico_sdk_init()
add_subdirectory("Arducam")
add_executable(pico_paper_detection
  source/main.cpp
include(${MODEL_FOLDER}/edge-impulse-sdk/cmake/utils.cmake)
target_link_libraries(pico_paper_detection
  PUBLIC Arducam
  pico_stdlib
target_include_directories(pico_paper_detection PUBLIC
  "${PROJECT_BINARY_DIR}"
  "${PROJECT_SOURCE_DIR}/Arducam"
# enable usb output, disable uart output
pico_enable_stdio_usb(pico_paper_detection 1)
pico_enable_stdio_uart(pico_paper_detection 0)
target_include_directories(pico_paper_detection PRIVATE
  ${MODEL_FOLDER}
  ${MODEL_FOLDER}/classifer
  ${MODEL_FOLDER}/tflite-model
  ${MODEL_FOLDER}/model-parameters
  ${EI_SDK_FOLDER}
  ${EI_SDK_FOLDER}/third_party/ruy
  ${EI_SDK_FOLDER}/third_party/gemmlowp
  ${EI_SDK_FOLDER}/third_party/flatbuffers/include
  ${EI_SDK_FOLDER}/tensorflow
  ${EI_SDK_FOLDER}/dsp
  ${EI_SDK_FOLDER}/classifier
  ${EI_SDK_FOLDER}/anomaly
  ${EI_SDK_FOLDER}/CMSIS/NN/Include
  ${EI_SDK_FOLDER}/CMSIS/DSP/PrivateInclude
  ${EI_SDK_FOLDER}/CMSIS/DSP/Include
  ${EI_SDK_FOLDER}/CMSIS/Core/Include
include_directories(${INCLUDES})
# find model source files
RECURSIVE_FIND_FILE(MODEL_FILES "${MODEL_FOLDER}/tflite-model" "*.cpp")
RECURSIVE_FIND_FILE(SOURCE_FILES "${EI_SDK_FOLDER}" "*.cpp")
RECURSIVE_FIND_FILE(CC_FILES "${EI_SDK_FOLDER}" "*.cc")
RECURSIVE_FIND_FILE(S_FILES "${EI_SDK_FOLDER}" "*.s")
RECURSIVE_FIND_FILE(C_FILES "${EI_SDK_FOLDER}" "*.c")
list(APPEND SOURCE_FILES ${S_FILES})
list(APPEND SOURCE_FILES ${C_FILES})
list(APPEND SOURCE_FILES ${CC_FILES})
list(APPEND SOURCE_FILES ${MODEL_FILES})
# add all sources to the project
target_sources(pico_paper_detection PRIVATE ${SOURCE_FILES})
pico_add_extra_outputs(pico_paper_detection)
Here is the CMakeLists.txt in the Arducam directory that I modified:
# aux_source_directory(. DIR_LIB_SRCS)
# add_library(arducam ${DIR_LIB_SRCS})
# target_include_directories(arducam
#   PUBLIC
#   ${CMAKE_CURRENT_LIST_DIR}/.
# target_link_libraries(arducam pico_stdlib hardware_i2c hardware_spi)
# my modifications
add_library(Arducam arducam.c arducam.h ov2640.h)
target_link_libraries(Arducam pico_stdlib hardware_i2c hardware_spi)
target_include_directories(Arducam PUBLIC "${CMAKE_CURRENT_SOURCE_DIR}")```
Scratch this, I figured it out. The EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE is not the same size as the features array, and so that’s why its not showing the port. I still need help on the code on capturing image from the ov2640 and transferring it to the features array. The code I’ve been trying to based on is this github link again: RPI-Pico-Cam/tflmicro at master · ArduCAM/RPI-Pico-Cam · GitHub
Any help would be very much appreciated .
Thanks,
Hi there!
There is quite a lot to digest here. First of all, let me note that we do not support camera inference for RP2040 yet.
Are you using Arduino IDE or pico-sdk?
Hello there,
I am using the pico-sdk.
