Question/Issue: When I try to run the classify.py (python3 classify.py modelfile.eim) I get this error:
Project ID: 176862
I’m trying to identify different geometrical shapes in the image using a Raspberry Pi Cam v2.1. and the Raspberry Pi 4.
v4l2-ctl --list-devices:
bcm2835-codec-decode (platform:bcm2835-codec):
/dev/video10
/dev/video11
/dev/video12
/dev/video18
/dev/video31
/dev/media1
bcm2835-isp (platform:bcm2835-isp):
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/media3
/dev/media4
unicam (platform:fe801000.csi):
/dev/video0
/dev/video1
/dev/media2
rpivid (platform:rpivid):
/dev/video19
/dev/media0
v4l2-ctl --device=/dev/video0 --all:
Driver Info:
Driver name : unicam
Card type : unicam
Bus info : platform:fe801000.csi
Driver version : 5.15.84
Capabilities : 0xa5a00001
Video Capture
Metadata Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x25200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Media Driver Info:
Model : unicam
Serial :
Media version : 5.15.84
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x01000005 : 0: Sink
Link 0x02000008: from remote pad 0x1000002 of entity 'imx219 10-0010': Data, Enabled, Immutable
Priority: 2
Video input : 0 (unicam-image: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'BGR3' (24-bit BGR 8-8-8)
Field : None
Bytes per Line : 1920
Size Image : 921600
Colorspace : sRGB
Transfer Function : sRGB
YCbCr/HSV Encoding: ITU-R 601
Quantization : Full Range
Flags :
