Test multiple datasets locally
Hey! I read the guide here On your desktop computer - Edge Impulse Documentation
Is there a way to test the impulse on multiple files and read the inference locally? Using the described method here On your desktop computer - Edge Impulse Documentation is a bit cumbersome when a compilation for each dataset is required.
Thank you!
  • Are you on Windows or Linux?
  • What sensors do you want to use?
  • Are you using a microcontroller connected to sensors to run your Model?
  • Do you want to use a web camera connected to your PC?
