I’m having trouble with the recognition of different tap sequence (i.e. tap, double tap, tap).
I’m trying to teach my model with Spectrogram and Spectral Analysis processing blocks and Neural Network (Keras) learning block. I’m not sure which parameters should I use. Can someone help plz?
Which filter should I use to filter out ringing after a tap. Main goal of the model is to differentiate between multiple tap sequencies based on the time between peaks while disregarding the amplitude of peaks.
Link to project: https://studio.edgeimpulse.com/studio/25257/
Thank you =)
