I’m training and deploying a simple model with the Syntiant board and some audio that I’ve collected myself - basically the audio dataset has binary labels; either “on” or “off.” The default 1D CNN trains fine and gives good accuracy, F1, etc.
When I run the “Find Posterior Parameters” routine under “Deployment” I get the following error message. I’m not adding any data augmentation, and I haven’t added any layers. Any idea what might be going on? A quick google search shows that this error often pops up when there’s a typo in the Keras code, but I couldn’t find anything obvious when switching to the Keras mode rather than the visual mode. Thanks for any help!
Copying neural network…
Copying neural network OK
Converting and evaluating unquantized neural network…
File “/app/app/get_posterior.py”, line 298, in
model.load_weights(weights_path)
File “/usr/local/lib/python3.6/site-packages/tensorflow/python/keras/engine/training.py”, line 2211, in load_weights
hdf5_format.load_weights_from_hdf5_group(f, self.layers)
File “/usr/local/lib/python3.6/site-packages/tensorflow/python/keras/saving/hdf5_format.py”, line 686, in load_weights_from_hdf5_group
’ layers.’)
ValueError: You are trying to load a weight file containing 3 layers into a model with 4 layers.
