I have been using a Logitech c270 webcam to train and test a voice model to a Raspberry Pi 4B. Everything went fine. I was able to download the model and run it on the Raspberry Pi 4B with no problem.
I wanted to use a smaller mic for the project and have purchased a USB Lavalier mic. When I connected the Lavalier mic to the Raspberry Pi 4B, I was able to test out the model on the Studio in the Live Classification mode. See the terminal output below
pi@raspberrypi:~/linux-sdk-python/examples/audio $ edge-impulse-linux --disable-camera
Edge Impulse Linux client v1.3.1
[SER] Using microphone hw:1,0
[WS ] Device "rasp1" is now connected to project "Waignaujai"
[WS ] Go to https://studio.edgeimpulse.com/studio/80471/acquisition/training to build your machine learning model!
path: '/api/testing/data',
label: 'testing',
length: 3000,
interval: 0.0625,
hmacKey: 'd3fe508d0eeb932049c38ee0b636edbe',
sensor: 'Microphone'
[SER] Waiting 2 seconds
[SER] Recording audio...
[SER] Uploading sample to https://ingestion.edgeimpulse.com/api/testing/data...
[SER] Sampling finished
[WS ] Trying to connect in 1 second...
I then downloaded the model using the CLI
pi@raspberrypi:~/EImodels $ edge-impulse-linux-runner --download yesNoModel.eim
Edge Impulse Linux runner v1.3.1
[RUN] Downloading model...
[BLD] Created build job with ID 2188028
[BLD] Writing templates...
[BLD] Scheduling job in cluster...
[BLD] Job started
[BLD] Building binary...
[BLD] arm-linux-gnueabihf-g++ -MD -Wall -g -Wno-strict-aliasing -I. -Isource -Imodel-parameters -Itflite-model -Ithird_party/ -Os -DNDEBUG -DEI_CLASSIFIER_ENABLE_DETECTION_POSTPROCESS_OP=1 -g -DEI_CLASSIFIER_USE_FULL_TFLITE=1 -Iedge-impulse-sdk/tensorflow-lite -std=c++14 -c source/main.cpp -o source/main.o
[BLD] arm-linux-gnueabihf-g++ -MD -Wall -g -Wno-strict-aliasing -I. -Isource -Imodel-parameters -Itflite-model -Ithird_party/ -Os -DNDEBUG -DEI_CLASSIFIER_ENABLE_DETECTION_POSTPROCESS_OP=1 -g -DEI_CLASSIFIER_USE_FULL_TFLITE=1 -Iedge-impulse-sdk/tensorflow-lite -std=c++14 -c tflite-model/tflite-trained.cpp -o tflite-model/tflite-trained.o
[BLD] In file included from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/vector:63,
[BLD] from source/main.cpp:8:
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_uninitialized.h: In function '_ForwardIterator std::__uninitialized_copy_a(_InputIterator, _InputIterator, _ForwardIterator, std::allocator<_Tp>&) [with _InputIterator = std::move_iterator<nlohmann::basic_json<>*>; _ForwardIterator = nlohmann::basic_json<>*; _Tp = nlohmann::basic_json<>]':
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_uninitialized.h:287:5: note: parameter passing for argument of type 'std::move_iterator<nlohmann::basic_json<>*>' changed in GCC 7.1
[BLD] __uninitialized_copy_a(_InputIterator __first, _InputIterator __last,
[BLD] ^~~~~~~~~~~~~~~~~~~~~~
[BLD] In file included from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/vector:69,
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/vector.tcc: In member function 'void std::vector<_Tp, _Alloc>::_M_realloc_insert(std::vector<_Tp, _Alloc>::iterator, _Args&& ...) [with _Args = {nlohmann::basic_json<std::map, std::vector, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, bool, long long int, long long unsigned int, double, std::allocator, nlohmann::adl_serializer, std::vector<unsigned char, std::allocator<unsigned char> > >}; _Tp = nlohmann::basic_json<>; _Alloc = std::allocator<nlohmann::basic_json<> >]':
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/vector.tcc:413:7: note: parameter passing for argument of type 'std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > >::iterator' {aka '__gnu_cxx::__normal_iterator<nlohmann::basic_json<>*, std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >'} changed in GCC 7.1
[BLD] vector<_Tp, _Alloc>::
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_uninitialized.h:311:2: note: parameter passing for argument of type 'std::move_iterator<nlohmann::basic_json<>*>' changed in GCC 7.1
[BLD] return std::__uninitialized_copy_a
[BLD] ~~~~~~~~~~~~~~~~~~~~~~~~~~~
[BLD] (_GLIBCXX_MAKE_MOVE_IF_NOEXCEPT_ITERATOR(__first),
[BLD] ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[BLD] _GLIBCXX_MAKE_MOVE_IF_NOEXCEPT_ITERATOR(__last), __result, __alloc);
[BLD] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/vector.tcc: In member function 'void std::vector<_Tp, _Alloc>::emplace_back(_Args&& ...) [with _Args = {nlohmann::basic_json<std::map, std::vector, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, bool, long long int, long long unsigned int, double, std::allocator, nlohmann::adl_serializer, std::vector<unsigned char, std::allocator<unsigned char> > >}; _Tp = nlohmann::basic_json<>; _Alloc = std::allocator<nlohmann::basic_json<> >]':
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/vector.tcc:109:4: note: parameter passing for argument of type '__gnu_cxx::__normal_iterator<nlohmann::basic_json<>*, std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >' changed in GCC 7.1
[BLD] _M_realloc_insert(end(), std::forward<_Args>(__args)...);
[BLD] In file included from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/char_traits.h:39,
[BLD] from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/ios:40,
[BLD] from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/ostream:38,
[BLD] from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/iostream:39,
[BLD] from source/main.cpp:4:
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_algobase.h: In function '_OI std::move(_II, _II, _OI) [with _II = __gnu_cxx::__normal_iterator<nlohmann::basic_json<>*, std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >; _OI = std::back_insert_iterator<std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >]':
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_algobase.h:479:5: note: parameter passing for argument of type '__gnu_cxx::__normal_iterator<nlohmann::basic_json<>*, std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >' changed in GCC 7.1
[BLD] move(_II __first, _II __last, _OI __result)
[BLD] ^~~~
[BLD] In file included from /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/vector:64,
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_vector.h: In member function 'void std::vector<_Tp, _Alloc>::reserve(std::vector<_Tp, _Alloc>::size_type) [with _Tp = nlohmann::basic_json<>; _Alloc = std::allocator<nlohmann::basic_json<> >]':
[BLD] /toolchains/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/arm-linux-gnueabihf/include/c++/8.3.0/bits/stl_vector.h:1401:35: note: parameter passing for argument of type 'std::move_iterator<nlohmann::basic_json<>*>' changed in GCC 7.1
[BLD] std::__uninitialized_copy_a(__first, __last, __result,
[BLD] ~~~~~~~~~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~
[BLD] _M_get_Tp_allocator());
[BLD] In file included from source/main.cpp:10:
[BLD] third_party/json/json.hpp: In member function 'void nlohmann::basic_json<ObjectType, ArrayType, StringType, BooleanType, NumberIntegerType, NumberUnsignedType, NumberFloatType, AllocatorType, JSONSerializer, BinaryType>::json_value::destroy(nlohmann::basic_json<ObjectType, ArrayType, StringType, BooleanType, NumberIntegerType, NumberUnsignedType, NumberFloatType, AllocatorType, JSONSerializer, BinaryType>::value_t) [with ObjectType = std::map; ArrayType = std::vector; StringType = std::__cxx11::basic_string<char>; BooleanType = bool; NumberIntegerType = long long int; NumberUnsignedType = long long unsigned int; NumberFloatType = double; AllocatorType = std::allocator; JSONSerializer = nlohmann::adl_serializer; BinaryType = std::vector<unsigned char>]':
[BLD] third_party/json/json.hpp:17759:26: note: parameter passing for argument of type '__gnu_cxx::__normal_iterator<nlohmann::basic_json<>*, std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >' changed in GCC 7.1
[BLD] std::move(array->begin(), array->end(), std::back_inserter(stack));
[BLD] ~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[BLD] third_party/json/json.hpp:17780:30: note: parameter passing for argument of type '__gnu_cxx::__normal_iterator<nlohmann::basic_json<>*, std::vector<nlohmann::basic_json<>, std::allocator<nlohmann::basic_json<> > > >' changed in GCC 7.1
[BLD] std::move(current_item.m_value.array->begin(), current_item.m_value.array->end(),
[BLD] ~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
[BLD] std::back_inserter(stack));
[BLD] mkdir -p build
[BLD] arm-linux-gnueabihf-g++ edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_radix2_q15.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_radix2_f32.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_q15.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_f32.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_fast_f64.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_radix2_q31.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_fast_init_f64.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_init_q15.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_q31.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_radix4_f16.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_fast_f16.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_radix4_init_f16.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_f16.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_radix4_f32.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_rfft_fast_f32.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_q15.o edge-impulse-sdk/CMSIS/DSP/Source/TransformFunctions/arm_cfft_f32.o edge-impulse-
(some of the output deleted for brevity - Francis)
sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_logsumexp_dot_prod_f32.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_min_f16.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_entropy_f16.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_max_q31.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFu
[BLD] nctions/arm_min_q15.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_min_f32.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_entropy_f32.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_var_f16.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_kullback_leibler_f64.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_kullback_leibler_f32.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_rms_f16.o edge-impulse-sdk/CMSIS/DSP/Source/StatisticsFunctions/arm_min_q31.o source/main.o tflite-model/tflite-trained.o edge-impulse-sdk/dsp/kissfft/kiss_fft.o edge-impulse-sdk/dsp/kissfft/kiss_fftr.o edge-impulse-sdk/dsp/dct/fast-dct-fft.o ./edge-impulse-sdk/dsp/memory.o edge-impulse-sdk/porting/posix/ei_classifier_porting.o edge-impulse-sdk/porting/posix/debug_log.o edge-impulse-sdk/porting/mingw32/ei_classifier_porting.o edge-impulse-sdk/porting/mingw32/debug_log.o -o build/linux-impulse-runner -lm -lstdc++ -L./tflite/linux-armv7 -Wl,--no-as-needed -ldl -ltensorflow-lite -lcpuinfo -lfarmhash -lfft2d_fftsg -lfft2d_fftsg2d -lruy -lXNNPACK -lpthread
[BLD] Building binary OK
[RUN] Downloading model OK
[RUN] Stored model in /home/pi/EImodels/yesNoModel.eim
However, when I ran the audio classify.py example, I got a message “the audio device is not compatible”. See output below
pi@raspberrypi:~/linux-sdk-python/examples/audio $ python3 classify.py /home/pi/EImodels/yesNoModel.eim
Loaded runner for "Francis K Tse / Waignaujai"
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.front.0:CARD=4'
ALSA lib conf.c:4745:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5233:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.surround51.0:CARD=4'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.surround40.0:CARD=4'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.surround71.0:CARD=4'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.iec958.0:CARD=4,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
connect(2) call to /dev/shm/jack-1000/default/jack_0 failed (err=No such file or directory)
attempt to connect to server failed
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_a52.c:823:(_snd_pcm_a52_open) a52 is only for playback
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.vc4-hdmi.pcm.iec958.0:CARD=4,AES0=6,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2660:(snd_pcm_open_noupdate) Unknown PCM iec958:{AES0 0x6 AES1 0x82 AES2 0x0 AES3 0x2 CARD 4}
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm_dmix.c:1075:(snd_pcm_dmix_open) unable to open slave
1 --> USB Lavalier Microphone: Audio (hw:1,0)
3 --> pulse
4 --> default
Type the id of the audio device you want to use:
1
That device is not compatible
3 --> pulse
4 --> default
This did not happen with the Logitech c270 webcam. Did I do something wrong or do I have to pick a compatible USB mic to use? Does anyone have a USB mic they have successfully used on the Raspberry Pi 4B with Edge Impulse models?
Thanks,
Francis.
