The edge-impulse-run-impulse is getting stuck at the taking a photo stage as well ?
I am on ETA Compute Vision Board
Hi @E33933 I assume this is with a custom impulse? Could be (based on your other comments) that there’s not enough memory available for the framebuffer anymore. Can you try this with the firmware from https://docs.edgeimpulse.com/docs/eta-compute-ecm3532-ai-vision ?
Okay I will try this. Sorry, I am still learning but I am unfamiliar with how to get firmware from an open source like github, flashed onto my board. Any tips?
Hi @E33933 I mean just the firmware under Step 2 here https://docs.edgeimpulse.com/docs/eta-compute-ecm3532-ai-vision?_ga=2.10563446.31679061.1632730810-1252652237.1574934249#2-update-the-firmware - no need to build anything or get anything from GitHub.
