Strange MFE spectogram for 1000 Hz sine wave
@janjongboom, @aurel,
I have created a sine wave of 1000 Hz using sox command:
sox -n -r 44100 other_1000Hz.wav synth 1 sine 7000
When I show this spectogram for the MFE buillding block it looks as follows:
So it shows very high energy and also very low energy values around 1000Hz band.
I would not expect these “very low energy values”.
I would expect a single band around 1000Hz with constant high energy value.
FYI: MEL spectogram for same audio fragment in audacity:
@janvda, I’m going to replace the MFE spectrogram by a normal one. That should fix all of this.
The command you gave me generates a 7000Hz wave right? Otherwise I don’t know what I’m looking at :wink:
But here’s the new spectrogram block which will replace the MFE one. The latter is too confusing (also for me).
Indeed the command above generates a 7000Hz wave.
It looks very good ! :+1: :+1:
Also very good that the frequencies are mentioned in the y-axis.
