Stored token seems invalid, clearing cache
When I try to run “edge-impulse-daemon”, there is one connection error : Stored token seems invalid, clearing cache…
D:\work_space\nodejs>edge-impulse-daemon
Edge Impulse serial daemon v1.13.14
? What is your user name or e-mail address (edgeimpulse.com)? xxx
? What is your password? [hidden]
Failed to authenticate with Edge Impulse unable to verify the first certificate
Yesterday I have connected the edge-impulse com successfully, but now I can’t login, anyone else can help resolve it? Thanks.
Hello @rick.zhang,
Can you try resetting your password and use the new one please?
https://studio.edgeimpulse.com/forgot-password
@rick.zhang This looks like a certificate chain error… Are you behind a firewall or proxy by any chance?
If you’re using a proxy you can try:
SET HTTPS_PROXY=...
edge-impulse-daemon
Thanks for you two @janjongboom @louis
I had tried to reset password, or uninstall edge-impulse-cli and re-install it again under WIN10, but failed…
In the end, I installed edge-impulse-cli tool under uBuntu and resolved this problem.
Thanks again!
I have the same problem here:
Edge Impulse Linux client v1.3.0
Failed to authenticate with Edge Impulse connect ENETUNREACH 52.85.208.99:443 - Local (0.0.0.0:0)
Tried to reinstall edge-impulse-linux on Raspberry Pi 4, and tried to change my password, with no success.
solved!! I checked my gateway with sudo route -n
There it is - no Gateway IP. I typed this:
sudo route add default gw 192.168.1.1
Now its fine!
@louis I am facing the same issue unable to login help me solve this.
Failed to authenticate with Edge Impulse certificate is not yet valid.
Getting the above error when I run edge-impulse-linux
