I successfully started from the “continuous-audio-sampling” tutorial to create, train, deploy and test on an Arduino Nano 33 BLE Sense board, but have run into trouble trying to extend to control the enable_maf argument to “run_classifier_continuous” function.
If I am doing and interpreting correctly, the source code built & exported from Studio Deployment looks to include an old version of the run_classifier_continuous function in ei_run_classifier.h. This does not include the enable_maf argument, which has been added in later versions of the EI SDK, including present in the current github master version.
I am puzzled and suspicious though since I think that function was updated in commit on 12-April-2021, so can the EI Studio integration and source export of SDK really be missing that or have I done or interpreted something wrong?
I have repeated the steps 3 times now with fresh projects, and each time the exported source code seems to have the stale version of the above function.
Specifically in the exported code I am looking at the following function:
<myHomePath>/Downloads/<myProjectName>/src/edge-impulse-sdk/classifier/ei_run_classifier.h
extern "C" EI_IMPULSE_ERROR run_classifier_continuous(signal_t *signal, ei_impulse_result_t *result,
bool debug = false)
Where I had expected to see the newer arguments as here:
bool debug = false, bool enable_maf = true)
from github master: inferencing-sdk-cpp/ei_run_classifier.h at master · edgeimpulse/inferencing-sdk-cpp · GitHub
Please can you help confirm if there is an issue here, or if I have done something wrong or mis-interpreted?
Outline of minimum steps in studio.edgeimpulse.com:
- Create project
- Import data
- Create impulse design: MFCC + NN Classifier 1D Conv; generate features & train model
- Deployment: Arduino Library; build
- Inspect the exported source code for /src/edge-impulse-sdk/classifier/ei_run_classifier.h
(I tried to include more links to be helpful but not allowed as a newcomer here)
