Speeding object detection process
I made a object detection program for 5 things, and i want to move servos sg90 in some way when one of those thinks are detected, but the detection of objects is very slow, and i whant to know how to make it faster. to compile and upload the program to my ESP32 CAM (ESP-32S) there was some errors, that i fixed turning EI_CLASSIFIER_TFLITE_ENABLE_ESP_NN to “0”, in conv.cpp and depthwise_conv.cpp.
  • Build Environment Details: Arduino IDE 2.3.3 ESP32 by espressif 3.0.5
  • OS Version: Windows 10
  • Edge Impulse Version (Firmware): 1.0.4
#include <Proyecto_Copitl_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
#include <ESP32Servo.h>
Servo myServo;
const int servoPin = 12;
#define led 4
//#define CAMERA_MODEL_ESP_EYE
#define CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 4
#define SIOD_GPIO_NUM 18
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 36
#define Y8_GPIO_NUM 37
#define Y7_GPIO_NUM 38
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 35
#define Y4_GPIO_NUM 14
#define Y3_GPIO_NUM 13
#define Y2_GPIO_NUM 34
#define VSYNC_GPIO_NUM 5
#define HREF_GPIO_NUM 27
#define PCLK_GPIO_NUM 25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#else
#error "Camera model not selected"
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
//bool t = 0;
static bool debug_nn = false;
uint8_t *snapshot_buf;
  .pin_pwdn = PWDN_GPIO_NUM,
  .pin_reset = RESET_GPIO_NUM,
  .pin_xclk = XCLK_GPIO_NUM,
  .pin_d7 = Y9_GPIO_NUM,
  .pin_d6 = Y8_GPIO_NUM,
  .pin_d5 = Y7_GPIO_NUM,
  .pin_d4 = Y6_GPIO_NUM,
  .pin_d3 = Y5_GPIO_NUM,
  .pin_d2 = Y4_GPIO_NUM,
  .pin_d1 = Y3_GPIO_NUM,
  .pin_d0 = Y2_GPIO_NUM,
  .pin_vsync = VSYNC_GPIO_NUM,
  .pin_href = HREF_GPIO_NUM,
  .pin_pclk = PCLK_GPIO_NUM,
  .xclk_freq_hz = 20000000,
  .ledc_timer = LEDC_TIMER_0,
  .pixel_format = PIXFORMAT_JPEG,
  .frame_size = FRAMESIZE_QVGA,
  .jpeg_quality = 12,
  .fb_count = 1,
bool ei_camera_init(void);
void ei_camera_deinit(void);
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf);
* @brief
void setup() {
  Serial.begin(115200);
  //myServo.attach(servoPin);
  pinMode(led, OUTPUT);
  //digitalWrite(led, LOW);
  while (!Serial)
  } else {
  ei_sleep(2000);
* @param[in]  debug  Get debug info if true
void loop() {
    return;
  snapshot_buf = (uint8_t *)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
  if (snapshot_buf == nullptr) {
    return;
  ei::signal_t signal;
    free(snapshot_buf);
    return;
  if (err != EI_IMPULSE_OK) {
    return;
  ei_printf("Object detection bounding boxes:\r\n");
    if (bb.value == 0) {
      continue;
    if (bb.label == 'lata') {
      Serial.println("Mover servo");
      digitalWrite(led, HIGH);
      delay(1000);
      while (t = 0) {
        // Move the servo to the starting position (0 degrees)
        myServo.write(0);
        delay(1000);  // Wait for 1 second
        // Move the servo to the middle position (90 degrees)
        myServo.write(90);
        // Move the servo to the ending position (180 degrees)
        myServo.write(180);
        t = 1;
    ei_printf("  %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
              bb.label,
              bb.value,
              bb.x,
              bb.y,
              bb.width,
              bb.height);
#else
  ei_printf("Predictions:\r\n");
    ei_printf("  %s: ", ei_classifier_inferencing_categories[i]);
    ei_printf("%.5f\r\n", result.classification[i].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY
  ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
#endif
#if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
  ei_printf("Visual anomalies:\r\n");
  for (uint32_t i = 0; i < result.visual_ad_count; i++) {
    ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
      continue;
              bb.label,
              bb.value,
              bb.x,
              bb.y,
              bb.width,
              bb.height);
#endif
  free(snapshot_buf);
  t = 0;
 * @brief
 * @retval
bool ei_camera_init(void) {
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  if (err != ESP_OK) {
    return false;
  sensor_t *s = esp_camera_sensor_get();
    s->set_vflip(s, 1);
    s->set_brightness(s, 1);
    s->set_saturation(s, 0);
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
  s->set_vflip(s, 1);
  s->set_awb_gain(s, 1);
#endif
  is_initialised = true;
  return true;
 * @brief
void ei_camera_deinit(void) {
    ei_printf("Camera deinit failed\n");
    return;
  return;
 * @brief
 * @param[in]  img_width
 * @param[in]  img_height
 * @param[in]  out_buf
 * @retval
  bool do_resize = false;
  if (!is_initialised) {
    return false;
  if (!fb) {
    return false;
  esp_camera_fb_return(fb);
  if (!converted) {
    ei_printf("Conversion failed\n");
    return false;
    do_resize = true;
  if (do_resize) {
      out_buf,
      EI_CAMERA_RAW_FRAME_BUFFER_COLS,
      out_buf,
      img_width,
      img_height);
  return true;
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr) {
  size_t pixel_ix = offset * 3;
  size_t pixels_left = length;
  size_t out_ptr_ix = 0;
  while (pixels_left != 0) {
    out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
    out_ptr_ix++;
    pixel_ix += 3;
    pixels_left--;
  return 0;
#endif
