On the site when I open the Spectral Features tab, I see the following error Error: Digital filter critical frequencies must be 0 < Wn < 1. So I try to make the critical frequency half of the sampling frequency to solve this. I press Save Parameters button to save the settings.
Then I open the the Generate features sub tab and press the Generate Features button, I am greeted with the following error.
Creating job... OK (ID: 183979)
Creating windows from 6 files...
[1/6] Creating windows from files...
[6/6] Creating windows from files...
Created 18 windows: M: 9, O: 9
Scheduling job in cluster...
Job started
Creating features
File "/home/create_features.py", line 61, in <module>
f = generate_features(False, example[1:], axes, freq, scale_axes=1, filter_cutoff=15, filter_order=6, fft_length=128, spectral_peaks_count=3, spectral_peaks_threshold=0.1, spectral_power_edges="0.1, 0.5, 1.0, 2.0, 5.0", filter_type="low")
File "/home/dsp.py", line 146, in generate_features
fx = filter(filter_type, sampling_freq, filter_cutoff * 2, filter_order, fx)
File "/home/dsp.py", line 12, in filter
[b, a] = signal.butter(filt_order, Wn=Wn, btype=type)
File "/usr/local/lib/python3.7/site-packages/scipy/signal/filter_design.py", line 2858, in butter
output=output, ftype='butter', fs=fs)
File "/usr/local/lib/python3.7/site-packages/scipy/signal/filter_design.py", line 2341, in iirfilter
raise ValueError("Digital filter critical frequencies "
ValueError: Digital filter critical frequencies must be 0 < Wn < 1
Job failed (see above)
Kindly advise.
