SparkFun MicroMod board: [SER] Failed to get information off device No valid sensor readings received from device
Hello, I created a model and project following the SparkFun workshop that was conducted on 30 June. Everything worked perfectly and ran great.
However, I wanted to update my model to include anomaly detection. When I tried to reconnect to Edge Impulse via the CLI data forwarder, I received the following error:
[SER] Failed to get information off device No valid sensor readings received from device.
I tried connecting via the daemon and received a timeout (even doing the --clean option). I saw a couple other topics on the forum to hit the reset twice and unplug USB/reconnect (didn’t work) or to reload firmware. I didn’t think that was a step in the workshop. We had to copy a custom mbed folder into the Arduino folder but I don’t remember doing a fw push to the board.
Any help would be appreciated!
Hello @jlutzwpi,
Can you make sure that the data-forwarder arduino sketch is the one running on your board?
The daemon won’t work here as the board is not officially supported.
