When I ran the daemon on Windows I got
Edge Impulse serial daemon v1.6.4
WARN: You're running an outdated version of the Edge Impulse CLI tools
Upgrade via `npm update -g edge-impulse-cli`
Stored token seems invalid, clearing cache...
I ran the npm command to update and after the update it said + edge-impulse-cli@1.7.0 . So I ran the daemon again and it seemed to be working fine.
I am using a Nano 33 BLE Sense and attempted to record multiple 7s duration sound clips. However after a couple of successful recordings, on the next attempt the UI would pop up an error suggesting that it was no longer connected. Also the Terminal wasn’t showing the usual:
path: '/api/training/data',
label: 'washing_machine_finish',
length: 7000,
interval: 0.0625,
hmacKey: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
sensor: 'Built-in microphone'
I have had this in the past, but less frequently and usually refreshing the page in Chrome would fix it.
The only way I could fix it was to disconnect, reconnect, re-run daemon, but again I would only get a couple of recordings before it failed again.
Will check the logs to see if we can determine what went wrong there.
