Some issues with Arduino Nano 33 BLE Sense
Hey all! I’m a real newbie to the whole scene, and currently working on a project to detect crying infants.
My issue is that after uploading the sketch to the Arduino, I get the following errors in the Arduino IDE’s serial monitor:
ERR: Failed to run DSP process (-1013)
ERR: Failed to run classifier (-5)
These repeat over and over again.
I’m not sure if it’s relevant, but when I run the edge-impulse-daemon, I see the following errors repeated over and over as well:
Project ID 194801
Not sure what to put for Context/Use case
If anyone can offer any help, I’d appreciate greatly.
Thanks!
Are you using a Rev 2 Arduino Nano board?
Yes, it’s the Rev2 board, which I recently noticed is not yet supported by Edge Impulse.
I did however get it to work when I used the bootloader, so still not sure what’s causing the issue.
how dd you use the bootloader? i am also trying to get this board to work with microphone
Hello @habsfan37,
Maybe you’d like to have a look at this thread too: Deploying audio classification model on computer or mobile phone not working? - #2 by louis
