Question/Issue: Hello, I am collecting sound or grain weevils in a soundproof controlled box using an Arduino Nano 33 BLE Sense. I was able to collect a few audio files using Edge Impulse Studio, but I have been experiencing writing failure after 2 to 3 and sometimes 4 recordings of 10 seconds. So, I have to disconnect the device and re-connect to continue with the data collection.
So, I decided to work on the PDM library in order to have audio signals and thereafter, I managed to create a Python script that will read audio data from the serial and save it into the directory I have specified. So far, I have generated audio files, but the quality is not as good as it is in Edge Impulse Studio. The purpose of this approach is to collect more audio data, which I could then upload to Edge Impulse Studio for model development.
I would like to seek your advice on my case and how I can improve the quality of my audio files.
Thank you.
Arduino Code:
#include <PDM.h>
// Default number of output channels
static const char channels = 1;
// default PCM output frequency
static const int frequency = 16000;
// Buffer size for reading samples
const int BUFFER_SIZE = 256;
// Buffer to read samples into, each sample is 16-bit
int16_t sampleBuffer[BUFFER_SIZE];
// Number of audio samples read
volatile int samplesRead;
void setup() {
Serial.begin(9600);
while (!Serial); // Wait for serial connection
// Configure the data receive callback
PDM.onReceive(onPDMdata);
// optionally set the gain, defaults to 20
// PDM.setGain(30);
// Initialize PDM with:
// - one channel (mono mode)
// - a 22050 Hz sample rate (adjust as needed)
if (!PDM.begin(channels, frequency)) {
Serial.println("Failed to start PDM!");
while (1);
// Adjust the gain as needed
PDM.setGain(30);
void loop() {
// Wait for samples to be read
if (samplesRead) {
// Send the audio data over the serial port as comma-separated values
for (int i = 0; i < samplesRead; i++) {
Serial.print(sampleBuffer[i]);
if (i < samplesRead - 1) {
Serial.print(",");
Serial.print(",");
// Clear the read count
samplesRead = 0;
Serial.println();
* Callback function to process the data from the PDM microphone.
* NOTE: This callback is executed as part of an ISR.
* Therefore using `Serial` to print messages inside this function isn't supported.
void onPDMdata() {
// Query the number of available bytes
int bytesAvailable = PDM.available();
// Read into the sample buffer
PDM.read(sampleBuffer, bytesAvailable);
// 16-bit, 2 bytes per sample (little-endian)
samplesRead = bytesAvailable / 2;
Python Script:
import argparse
import wave
import struct
import os
import serial
import serial.tools.list_ports
import time
import numpy as np
from scipy.signal import butter, sosfilt, lfilter, freqz
# Default values
DEFAULT_BAUD = 9600
DEFAULT_LABEL = 'audio'
SAMPLE_RATE = 16000 # Adjust as needed
CHUNK_DURATION = 10 # Duration of each audio chunk in seconds
# Bandpass filter parameters
LOWCUT = 3000 # Lower cutoff frequency (Hz)
HIGHCUT = 5000 # Higher cutoff frequency (Hz)
ORDER = 4 # Filter order
# Normalize cutoff frequencies
LOWCUT_NORM = LOWCUT / (SAMPLE_RATE / 2)
HIGHCUT_NORM = HIGHCUT / (SAMPLE_RATE / 2)
sos = butter(ORDER, [LOWCUT_NORM, HIGHCUT_NORM], btype='band', output='sos')
# Parse arguments
parser = argparse.ArgumentParser(description="Serial Audio Data Collection")
parser.add_argument('-p', '--port', dest='port', type=str, required=True, help="Serial port to connect to")
parser.add_argument('-b', '--baud', dest='baud', type=int, default=DEFAULT_BAUD, help="Baud rate (default = " + str(DEFAULT_BAUD) + ")")
parser.add_argument('-d', '--directory', dest='directory', type=str, default=".", help="Output directory for files (default =.)")
parser.add_argument('-l', '--label', dest='label', type=str, default=DEFAULT_LABEL, help="Label for files (default = " + DEFAULT_LABEL + ")")
args = parser.parse_args()
port = args.port
baud = args.baud
out_dir = args.directory
label = args.label
# Spectral subtraction parameters
OVERSUBTRACTION_FACTOR = 1.0 # Adjust as needed
NOISE_SAMPLE_LENGTH = 1000 # Length of the noise sample for noise spectrum estimation
# Notch filter parameters
NOTCH_FREQ = 3.0 # Frequency to be notched (e.g., 60 Hz for power line noise)
NOTCH_Q = 1.0 # Quality factor for the notch filter
# Wiener filter parameters
WIENER_WINDOW_LENGTH = 256 # Length of the window for Wiener filtering
def spectral_subtraction(signal, noise_mean):
Apply spectral subtraction to a signal using a given noise spectrum.
Args:
signal (np.ndarray): Input signal.
noise_mean (np.ndarray): Noise spectrum estimate.
Returns:
np.ndarray: Signal with noise reduced by spectral subtraction.
signal_spectrum = np.fft.fft(signal)
signal_magnitude = np.abs(signal_spectrum)
subtracted_magnitude = signal_magnitude**2 - OVERSUBTRACTION_FACTOR * noise_mean**2
subtracted_magnitude = np.maximum(subtracted_magnitude, 0) # Ensure non-negative values
subtracted_magnitude = np.sqrt(subtracted_magnitude)
# Reconstruct the signal with the subtracted spectrum
subtracted_spectrum = subtracted_magnitude * np.exp(1j * np.angle(signal_spectrum))
enhanced_signal = np.fft.ifft(subtracted_spectrum).real
return enhanced_signal
def notch_filter(signal, notch_freq, notch_q, sample_rate=SAMPLE_RATE):
Apply a notch filter to remove a specific frequency component from the signal.
Args:
notch_freq (float): Frequency to be notched (in Hz).
notch_q (float): Quality factor for the notch filter.
sample_rate (int): Sample rate of the signal (default: SAMPLE_RATE).
Returns:
np.ndarray: Signal with the notched frequency component removed.
notch_freq_norm = notch_freq / (sample_rate / 2) # Normalize frequency
notch_bandwidth = notch_freq_norm / notch_q # Calculate the bandwidth
low_cutoff = notch_freq_norm - notch_bandwidth / 2
high_cutoff = notch_freq_norm + notch_bandwidth / 2
b_notch, a_notch = butter(ORDER, [low_cutoff, high_cutoff], btype='bandstop', analog=False, output='ba')
filtered_signal = lfilter(b_notch, a_notch, signal)
return filtered_signal
def wiener_filter(signal, window_length=WIENER_WINDOW_LENGTH):
Apply a Wiener filter to the signal for noise reduction.
Args:
window_length (int): Length of the window for Wiener filtering (default: WIENER_WINDOW_LENGTH).
Returns:
np.ndarray: Signal with noise reduced by Wiener filtering.
window_length = min(window_length, len(signal))
padded_signal = np.pad(signal, (window_length // 2, window_length // 2), mode='constant')
filtered_signal = np.zeros_like(signal)
for i in range(len(signal)):
window = padded_signal[i:i + window_length]
window_mean = np.mean(window)
filtered_signal[i] = window_mean
# Print out available serial ports
print()
print("Available serial ports:")
available_ports = serial.tools.list_ports.comports()
for port, desc, hwid in sorted(available_ports):
print(" {} : {} [{}]".format(port, desc, hwid))
# Parse arguments
port = args.port
baud = args.baud
label = args.label
print(f"Connected to: {port} successfully")
# Configure serial port
ser = serial.Serial()
ser.port = port
ser.baudrate = baud
# Attempt to connect to the serial port
try:
ser.open()
except Exception as e:
print("ERROR:", e)
exit()
# Make output directory
try:
os.makedirs(out_dir)
except FileExistsError:
pass
# Audio configuration
CHANNELS = 1
SAMPLE_WIDTH = 2 # 2 bytes per sample (16-bit)
try:
while True:
# Read data from the serial port for 10 seconds
data_list = []
start_time = time.time()
while time.time() - start_time < CHUNK_DURATION:
data_str = ser.readline().decode('utf-8').strip()
if data_str:
data_list.extend([int(x) for x in data_str.split(',') if x])
# Apply bandpass filter
data_filtered = sosfilt(sos, data_list)
# Normalize the audio data
data_normalized = (data_filtered - np.min(data_filtered)) / (np.max(data_filtered) - np.min(data_filtered))
# Estimate the noise spectrum from the first few samples
noise_sample = data_normalized[:NOISE_SAMPLE_LENGTH]
noise_mean = np.mean(np.abs(np.fft.fft(noise_sample))**2)
# Apply spectral subtraction
data_enhanced = spectral_subtraction(data_normalized, noise_mean)
# Apply notch filter
data_enhanced = notch_filter(data_enhanced, NOTCH_FREQ, NOTCH_Q)
# Apply Wiener filter
#data_enhanced = wiener_filter(data_enhanced)
# Pack the enhanced data into a byte string
#data_bytes = struct.pack(f'<{len(data_enhanced)}h', *(int(sample * 32767) for sample in data_enhanced))
# Clip the enhanced data to the valid range
data_enhanced = np.clip(data_enhanced, -1, 1)
# Pack the clipped data into a byte string
# Get the current timestamp
import datetime
timestamp = datetime.datetime.now().strftime('%Y-%m-%d_%H-%M-%S')
# Create a unique filename for the WAV file
import uuid
uid = str(uuid.uuid4())[-12:]
filename = f"{label}.{uid}.{timestamp}.wav"
audio_path = os.path.join(out_dir, filename)
# Open the WAV file and write the data
with wave.open(audio_path, 'w') as wav_file:
wav_file.setparams((CHANNELS, SAMPLE_WIDTH, SAMPLE_RATE, len(data_normalized), 'NONE', 'NONE'))
wav_file.writeframes(data_bytes)
print(f'Audio data saved to {audio_path}')
# Calculate elapsed time for this recording
elapsed_time = time.time() - start_time
if elapsed_time < CHUNK_DURATION:
time.sleep(CHUNK_DURATION - elapsed_time) # Wait for remaining time if needed
except KeyboardInterrupt:
pass
finally:
# Close the serial port
ser.close()
