Hi Louis,
I brought xG24 Dev Kit for my personal research project and was following getting started guide for this board to set it up for my apple silicon Mac which is not successful:
(base) Rams-MBP:EI ramkumarkoppu$ python --version
Python 3.12.3
(base) Rams-MBP:EI ramkumarkoppu$ npm --version
10.8.1
(base) Rams-MBP:EI ramkumarkoppu$ node -v
v20.16.0
(base) Rams-MBP:EI ramkumarkoppu$ npm install -g edge-impulse-cli --force
npm warn using --force Recommended protections disabled.
npm warn deprecated osenv@0.1.5: This package is no longer supported.
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm warn deprecated @zeit/dockerignore@0.0.5: “@zeit/dockerignore” is no longer maintained
npm warn deprecated move-concurrently@1.0.1: This package is no longer supported.
npm warn deprecated rimraf@2.7.1: Rimraf versions prior to v4 are no longer supported
npm warn deprecated figgy-pudding@3.5.2: This module is no longer supported.
npm warn deprecated npmlog@4.1.2: This package is no longer supported.
npm warn deprecated har-validator@5.1.5: this library is no longer supported
npm warn deprecated copy-concurrently@1.0.5: This package is no longer supported.
npm warn deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
npm warn deprecated fs-write-stream-atomic@1.0.10: This package is no longer supported.
npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1.
npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See There’s Math.random(), and then there’s Math.random() · V8 for details.
npm warn deprecated gauge@2.7.4: This package is no longer supported.
npm warn deprecated fstream@1.0.12: This package is no longer supported.
npm warn deprecated request@2.88.0: request has been deprecated,
changed 375 packages in 13s
15 packages are looking for funding
run npm fund
for details
(base) Rams-MBP:EI ramkumarkoppu$ edge-impulse-daemon
-bash: edge-impulse-daemon: command not found
this is my first use of EI and any help to install ‘edge-impulse-daemon’ on MacBook would be helpful
