Serialport-terminal: command not found
I am getting this error when I run:
serialport-terminal -b 115200
I thought it can be solved by running:
sudo ln -s ~/edge-impulse-cli/package/build/serial-daemon/cli/serialport-terminal.js /usr/local/bin/serialport-terminal
Yet, that didn’t solve it.
Kindly, advice.
@janjongboom
@mathijs
Yes, this is a different package. If you’re on Linux it’s probably easier to use screen:
If it’s not installed, install GNU screen ( sudo apt-get install screen ). Then open a terminal and find out the handler for your device:
$ ls /dev/ttyACM*
/dev/ttyACM0
Then connect to the board using screen:
sudo screen /dev/ttyACM0 115200                # might not need sudo if set up lsusb rules properly
To exit, press CTRL+A then type :quit .
Thanks.
