I’ve been trying to get the Silabs Thunderboard to connect to a Linux/Windows without success. The SiLabs works connecting directly to the phone but to Linux I get the following message :
edge-impulse-daemon
Edge Impulse serial daemon v1.11.2
? What is your user name or e-mail address (edgeimpulse.com)? username@hotmail.com
? What is your password? [hidden]
Endpoints:
Websocket:
API:
Ingestion:
[SER] Connecting to /dev/ttyACM0
[SER] Failed to get info off device Timeout
[SER] Serial closed - retrying in 5 seconds
I get the same message on 2 Raspberry Pis and a Ubuntu PC. Any tips? I’ve installed the firmware (copied the silabs-thunderboard-sense2.bin file to the board).
Any ideas?
@kelter101757, what do you mean with “works connecting directly to the phone” ?
Could you share what you see when you run:
$ edge-impulse-run-impulse --raw
And reset the board? You should see something like:
janjongboom:~ $ edge-impulse-run-impulse --raw
Edge Impulse impulse runner v1.12.0
[SER] Connecting to /dev/tty.usbmodem0004401610821
Hello from Edge Impulse Device SDK.
Compiled on Jan 27 2021 10:32:42
IMU init...OK
IMU device ID = E0h
IMU gyro calibration...OK
Gyroscope bias (deg/s) : gx: , gy: , gz:
IMU sample rate set to Hz (accel), Hz (gyro)
Loaded configuration
Type AT+HELP to see a list of commands.
Also, after you drag the .bin file to the board do you see a FAIL.txt file being created?
I do get a fail.txt after droping the bin file inside it. Inside the file it says “Error while connecting to CPU”. How do I correct that?
The edge impulse clients:
Edge-impulse-run-impulse --raw
Edge Impulse impulse runner v1.11.2
I managed to fix it by pressing buttons (Reset I think) and dropping the file over a few more times. Eventually, it started working.
Thanks for the help
