Serial Communication between ESP32CAM and Arduino UNO
Hi, I want to send a signal from ESP32CAM that runs FOMO model, to Arduino UNO via UART after ESP32CAM detects the object.
I tried to integrate this code below into Examples ESP32 Camera code generated from Arduino Library
#define RXp2 14
#define TXp2 15
void setup() {
  Serial.begin(9600);
  Serial2.begin(115200, SERIAL_8N1, RXp2, TXp2);
void loop() {
  for (int i =0; i<301; i++)
    Serial2.println(i);
    //Serial.println(Serial2.readString());
    Serial.print("sent packet ");Serial.println(i);
    delay(500);
Here’s is how I put the serial2.println to test it
void setup()
    Serial.begin(115200);
    while (!Serial);
    else {
    ei_sleep(2000);
        if (bb.value == 0) {
            continue;
        ei_printf("    %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
    if (!bb_found) {
        ei_printf("    No objects found\n");
#else
        ei_printf("    %s: %.5f\n", result.classification[ix].label,
        if (result.classification[ix].value > 0.1)
          Serial2.println("Detected");
          Serial.println("Detected"); //local serial print
          delay(500);
#endif
The problem is how can I serial print the results of result.classification[ix].label and
Thank you.
Hello @sio_yx,
If I am not mistaken, the ESP32-CAM has only one Serial interface.
I’d suggest to have a look at Espressif or Arduino’s forum as it’s more related to the code logic than the inference itself.
Hi @louis , the serial communication is successful if I try with other code. But I can’t integrate with code from edge impulse. Because when I serial print using the code below after ei_printf, it doesn’t show anything. So I wonder where should I put if else code to serial print result.classification[ix].label and result.classification[ix].value.
Your putting your code in wrong side of the compiler directive since you are doing FOMO.
        if (bb.value == 0) { continue; }
          delay(500);
    if (!bb_found) { ei_printf("    No objects found\n");  }
#else
#endif
Thank you ! Sorry, hadn’t seen your reply until now.
