The issue is to generate a signal from ESP32 CAM through GPIO Ports by detecting an object using a edge Impulse
There was no output since we cannot identify whether the signal is being generated
The code was written
The code was uploaded on ESP32 cam using arduino IDE
This is the code intialy that failed to send signals
ei_printf(“Object detection bounding boxes:\r\n”);
// Reset all GPIO signals to LOW at the start of each frame
digitalWrite(RIGHT_TURN_GPIO, LOW);
digitalWrite(LEFT_TURN_GPIO, LOW);
digitalWrite(STOP_GPIO, LOW);
bool detected = false; // Flag to track if any valid detection occurs
if (bb.value == 0) {
continue;
detected = true; // Set the flag if a bounding box is detected
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
// GPIO signal control based on bb.label
if (strcmp(bb.label, “right turn”) == 0) {
digitalWrite(RIGHT_TURN_GPIO, HIGH);
} else if (strcmp(bb.label, “left turn”) == 0) {
digitalWrite(LEFT_TURN_GPIO, HIGH);
} else if (strcmp(bb.label, “stop”) == 0) {
digitalWrite(STOP_GPIO, HIGH);
We expected to see the value High on the digital trainer
it showed nothing even though it detected an image
Always
