Seeed Xiao ESP32-S3 Sense Camera Object Detection with TFT Display
In the examples of the Edge Impulse library for Arduino with ESP32 boards with a camera, there is no image output with the bounding boxes drawn. Only the output in the Serial Monitor, with information about the inference.
I acquired a Seeed Xiao ESP32-S3 Sense and a Seeed Studio Round Display for Xiao, to run an object recognition project and decided to take on the challenge of adding this functionality to the original library example.
I followed the steps of the excellent tutorials written by Marcelo Rovai TinyML Made Easy: Object Detection with XIAO ESP32S3 Sense - Hackster.io and XIAO-ESP32S3-Sense/camera_round_display_save_jpeg at main · Mjrovai/XIAO-ESP32S3-Sense · GitHub and therefore I will not reproduce the steps here.
I’m just going to share the code with the comments and adaptations I made to be able to have the bounding boxes drawn on the TFT display at the same time the camera captures them.
/* Adding TFT Support Libraries */
#include <Arduino.h>
#include <TFT_eSPI.h>
#include <SPI.h>
/* Adding Edge Impulse Inferencing Library */
#include <Add_Your_inferencing_here.h> // Remember to change this line!
#include "edge-impulse-sdk/dsp/image/image.hpp"
/* Adding ESP32S3 Sense Camera Support */
#include "esp_camera.h"
/*  The bounding boxes were coming out small and the coordinates were out of place.
    I understood that, although the camera configuration points to 240x240,
    the images of the bounding boxes in the TFT were not in the same proportion.
    I decided to divide the maximum resolutions (1600x1200) by 240 and arrived at values 6.67 and 5.
#define MAX_WIDTH 1600
#define MAX_HEIGHT 1200
#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
#define PWDN_GPIO_NUM     -1
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM     10
#define SIOD_GPIO_NUM     40
#define SIOC_GPIO_NUM     39
#define Y9_GPIO_NUM       48
#define Y8_GPIO_NUM       11
#define Y7_GPIO_NUM       12
#define Y6_GPIO_NUM       14
#define Y5_GPIO_NUM       16
#define Y4_GPIO_NUM       18
#define Y3_GPIO_NUM       17
#define Y2_GPIO_NUM       15
#define VSYNC_GPIO_NUM    38
#define HREF_GPIO_NUM     47
#define PCLK_GPIO_NUM     13
#define TOUCH_INT D7
/* Original EDGE IMPULSE example parameters - Change Camera Capture to display same size as TFT */
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           240
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
/* Camera Config Parameters */
  .pin_pwdn = PWDN_GPIO_NUM,
  .pin_reset = RESET_GPIO_NUM,
  .pin_xclk = XCLK_GPIO_NUM,
  .pin_d7 = Y9_GPIO_NUM,
  .pin_d6 = Y8_GPIO_NUM,
  .pin_d5 = Y7_GPIO_NUM,
  .pin_d4 = Y6_GPIO_NUM,
  .pin_d3 = Y5_GPIO_NUM,
  .pin_d2 = Y4_GPIO_NUM,
  .pin_d1 = Y3_GPIO_NUM,
  .pin_d0 = Y2_GPIO_NUM,
  .pin_vsync = VSYNC_GPIO_NUM,
  .pin_href = HREF_GPIO_NUM,
  .pin_pclk = PCLK_GPIO_NUM,
  .xclk_freq_hz = 10000000,
  .ledc_timer = LEDC_TIMER_0,
  /* This config pixel format needed to be the same in function ei_camera_capture ()
                                                        HERE
     bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_RGB565, snapshot_buf);
  .pixel_format = PIXFORMAT_RGB565, //YUV422,GRAYSCALE,RGB565,JPEG
  .frame_size = FRAMESIZE_240X240,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
  .fb_count = 2,       //if more than one, i2s runs in continuous mode. Use only with JPEG
  .fb_location = CAMERA_FB_IN_PSRAM, // Frame Buffer in PSRAM - YES!
bool ei_camera_init(void);
void ei_camera_deinit(void);
/* Create TFT_SPI object */
TFT_eSPI tft = TFT_eSPI();
/* Bounding Boxes Coordinates need to be uint32_t in TFTeSPI Library */
uint32_t x;
uint32_t y;
uint32_t w;
uint32_t h;
  @brief      Arduino setup function
void setup()
  Serial.begin(115200);
  // while (!Serial);
  /* Init TFT */
  tft.init();
  /*   Need to set Rotation to 3 and change Camera Sensor
      Config to Sync coordinates of bounding boxes*/
  tft.setRotation(3);
  tft.fillScreen(TFT_WHITE);
  else {
  ei_sleep(2000);
  @brief      Get data and run inferencing
  @param[in]  debug  Get debug info if true
void loop()
    return;
  if (snapshot_buf == nullptr) {
    return;
  /* The signal that will be inferred is this one */
  ei::signal_t signal;
  /*  Makes the call to the ei_camera_capture function,
      which captures the image to the framebuffer,
      converts the image to the correct format and resizes it.
    free(snapshot_buf);
    return;
  // Run the classifier
  if (err != EI_IMPULSE_OK) {
    return;
  // Print the predictions to Serial Debug
  ei_printf("TFT Example -  Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
    if (bb.value == 0) {
      continue;
      commenting this line, just to compare dimensions above
      ei_printf("   %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
    /* Create Coordinates and Size for Bounding Boxes */
    x = bb.x;
    y = bb.y;
    w = bb.width * 6; // WIDTH MAX / CURRENT
    h = bb.height * 5; // HEIGHT MAX / CURRENT
    /* Checking Sizes */
    ei_printf("BB Coord [ x: %u, y: %u, width: %u, height: %u ]\n",  bb.x, bb.y, bb.width, bb.height);
    ei_printf("Percentage %u",  result.classification[0].value);
    /* Draw Bounding Boxes in Display */
    tft.drawRect (x, y, w, h, TFT_GREEN);
    tft.setCursor(x, y);
    tft.setTextColor(TFT_GREEN);
    tft.setTextFont(4);
    tft.println(bb.label);
    tft.endWrite();
  if (!bb_found) {
    ei_printf("TFT Example -     No objects found\n");
    tft.endWrite();
#else
    ei_printf("    %s: %.5f\n", result.classification[ix].label,
#endif
  ei_printf("TFT Example -     anomaly score: %.3f\n", result.anomaly);
#endif
  free(snapshot_buf);
   @brief   Setup image sensor & start streaming
   @retval  false if initialisation failed
bool ei_camera_init(void) {
  //initialize the camera
  if (err != ESP_OK) {
    return false;
  /*  You need to change these settings, otherwise
      the x and y coordinates of the TFT and the camera will be
      different from each other.
      It appears that the TFT is rotated 90 counterclockwise in relation to the camera...
  s->set_vflip(s, 1); // flip vertical
  s->set_hmirror(s, 1); // mirror horizontal
  is_initialised = true;
  return true;
   @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
  //deinitialize the camera
  if (err != ESP_OK)
    ei_printf("Camera deinit failed\n");
    return;
  return;
   @brief      Capture, rescale and crop image
   @param[in]  img_width     width of output image
   @param[in]  img_height    height of output image
   @param[in]  out_buf       pointer to store output image, NULL may be used
                             if ei_camera_frame_buffer is to be used for capture and resize/cropping.
   @retval     false if not initialised, image captured, rescaled or cropped failed
  bool do_resize = false;
  if (!is_initialised) {
    return false;
  if (!fb) {
    return false;
  /*  Write camera captured framebuffer into TFT Display */
  tft.startWrite();
  tft.setAddrWindow(0, 0, EI_CAMERA_RAW_FRAME_BUFFER_COLS, EI_CAMERA_RAW_FRAME_BUFFER_ROWS);
  tft.pushColors(fb->buf, fb->len);
  /*  Pay attention to this PIXFORMAT_RGB565 parameter in camera config. Need to be equal or convertion will fail  */
  esp_camera_fb_return(fb);
  if (!converted) {
    ei_printf("Conversion failed\n");
    return false;
    do_resize = true;
  if (do_resize) {
      out_buf,
      out_buf,
      img_width,
      img_height);
  return true;
  size_t pixel_ix = offset * 3;
  size_t pixels_left = length;
  size_t out_ptr_ix = 0;
  while (pixels_left != 0) {
    out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
    // go to the next pixel
    out_ptr_ix++;
    pixel_ix += 3;
    pixels_left--;
  // and done!
  return 0;
#endif
Hi @djairguilherme
Nice work!
@mjrovai will be happy to see this!
Can you print out the bounding box coordinates (x , y , w , h ) to the serial monitor along with any other relevant information during runtime.
Maybe there is something happening with the 90 degree screen rotation etc, paste the output here for the community to review and offer sugggestion :rocket:
