Scaling timestamp
Hi, I am working a process in HVAC system, monitoring discharge and suction pressure on a chiller.
The sample time is about 15 minutes (or 900 seconds), hence, the csv file fail to upload.
The pressure signal cycle is about one day.
In order to test, I am scaling the timestamp on 1/1000.
After results, how can I scale again in order to have the correct WA or Arduino library?
Regards.
This is a picture from de pressure signal.
Hi @julianflorez,
You will need to scale the EI_CLASSIFIER_MS in your code. This is the Arduino accelerometer example (not scaled):
        IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
        buffer[ix + 1] *= CONVERT_G_TO_MS2;
        buffer[ix + 2] *= CONVERT_G_TO_MS2;
You could also implement your own delay mechanism as I suppose your device goes to (deep) sleep between each sample. As long as you fill the buffer with the expected number of features this should work well.
