Scale Your TinyML Application with Edge Impulse and Azure IoT Edge
This article will give you an understanding on how models built with Edge Impulse may be used with IoT Edge on Microsoft Azure, enabling the models to be used in a large-scale solution. Azure IoT Edge is part of the IoT Hub where device identities can be created and managed. On supported devices, a container runtime is installed to let IoT Edge manage Docker containers, reffered to as modules. Along with this runtime and two system modules comes several benefits, as the possibility to update application parameters or the whole application itself, and logic around application messages and internet connectivity.
This is a companion discussion topic for the original entry at https://www.edgeimpulse.com/blog/scale-your-tinyml-application-with-edge-impulse-and-azure-iot-edge
