I have tried to run the sample Micro:bit project that I downloaded and compiled from GitHub, but it does not work. The LED in the middle lights up and the microphone is also lit up, but no matter how many times I say “microbit” I never see the smiley face. When I open the terminal it also never seems to register the word. Is there something I am doing wrong?
Yes. When I say “microbit” it ranges from .00195 normal volume level to .0137 with a loud voice.
@krobinsonbds I’ve pushed a model update with the model from Micro:bit LIVE with a lot higher sensitivity, can you give it a try? Just pull and rebuild!
Yes, that worked. Thank you very much.
Hi Jan, thank you first for making the video on voice activated with Micro:bit board. I have the same issue than @krobinsonbds. How did you do to help him to resolve the issue ? Thanks. Julien
Hi @Juph can you post the output of what you see when you run
edge-impulse-run-impulse --raw
(Or what you see on a serial monitor when you say the word)?
Also, just to confirm, you haven’t changed the word right?
Hi @janjongboom,
I confirm that I have not changed the keyword which is microbit.
Thanks for your help !
