Dear
good evening, currently i need to analyse data and run programs from two different sensors (the mic and accelerometer ), even in sequential manner, however, the sketch is running on one sensor at a time
please can i have guide on this
Hi @nizar, there’ll be naming conflicts in that case by default, but you could get it to work:
- Export two projects, one for every sensor.
- Look in the library that is exported, and add prefixes for all declarations in
model_metadata.h, the classes indsp_blocks.hand the declarations intflite-modelfolder. - Reference the right DSP blocks and Neural Networks in
ei_run_classifier.hfor both networks.
So possible at this point but requires some custom engineering. If we see more demand we can think of adding this as a supported format to the SDK, but not at this point.
thank you very much for your support and guide
Kindly one more clarifications, all declarations here mean library or variables, or both
thanks in advance
Hi @nizar, the #define's and the variables in the following files:
- model-parameters/anomaly_clusters.h
- model-parameters/anomaly_types.h
- model-parameters/dsp_blocks.h
- model-parameters/model_metadata.h
And all files in tflite-model.
