I am hoping to run the resulting model on my computer. I have messaged before about getting it running on a pc, it is working but it is EXTREMELY slow. I only have 2 things I am trying to see, a Humming bird, or that damn squirrel that bullies the humming bird.
I am trying to get my video from an IP cam feed, Would anyone be kind enough to have a look at my code and let me know if I am doing anything obviously wrong? or is my PC just too slow? I am using the optomized build. and my ip cam is delivering a 320x320 image already (i set that on the camera)
#include <unistd.h>
#include "opencv2/opencv.hpp"
#include "opencv2/videoio/videoio_c.h"
#include "iostream"
static bool use_debug = true;
// If you don't want to allocate this much memory you can use a signal_t structure as well
// and read directly from a cv::Mat object, but on Linux this should be OK
static float features[EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT];
* Resize and crop to the set width/height from model_metadata.h
void resize_and_crop(cv::Mat *in_frame, cv::Mat *out_frame) {
// to resize... we first need to know the factor
float factor_w = static_cast<float>(EI_CLASSIFIER_INPUT_WIDTH) / static_cast<float>(in_frame->cols);
float factor_h = static_cast<float>(EI_CLASSIFIER_INPUT_HEIGHT) / static_cast<float>(in_frame->rows);
float largest_factor = factor_w > factor_h ? factor_w : factor_h;
cv::Size resize_size(static_cast<int>(largest_factor * static_cast<float>(in_frame->cols)),
static_cast<int>(largest_factor * static_cast<float>(in_frame->rows)));
cv::Mat resized;
cv::resize(*in_frame, resized, resize_size);
int crop_x = resize_size.width > resize_size.height ?
(resize_size.width - resize_size.height) / 2 :
0;
int crop_y = resize_size.height > resize_size.width ?
(resize_size.height - resize_size.width) / 2 :
0;
cv::Rect crop_region(crop_x, crop_y, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT);
if (use_debug) {
printf("crop_region x=%d y=%d width=%d height=%d\n", crop_x, crop_y, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT);
*out_frame = resized(crop_region);
int main(int argc, char** argv) {
// If you see: OpenCV: not authorized to capture video (status 0), requesting... Abort trap: 6
// This might be a permissions issue. Are you running this command from a simulated shell (like in Visual Studio Code)?
// Try it from a real terminal.
if (argc < 2) {
printf("Requires one parameter (ID of the webcam).\n");
printf("You can find these via `v4l2-ctl --list-devices`.\n");
printf("E.g. for:\n");
printf(" C922 Pro Stream Webcam (usb-70090000.xusb-2.1):\n");
printf(" /dev/video0\n");
printf("The ID of the webcam is 0\n");
exit(1);
for (int ix = 2; ix < argc; ix++) {
if (strcmp(argv[ix], "--debug") == 0) {
printf("Enabling debug mode\n");
use_debug = true;
cv::VideoCapture vcap;
const std::string videoStreamAddress = "http://root:Link888*@192.168.2.19/mjpg/video.mjpg";
if(!vcap.open(videoStreamAddress)) {
std::cout << "Error opening video stream or file" << std::endl;
return -1;
} else {
std::cout << "VCAP open!" << std::endl;
// //open the webcam...
// cv::VideoCapture camera(atoi(argv[1]));
// if (!camera.isOpened()) {
// std::cerr << "ERROR: Could not open camera" << std::endl;
// return 1;
cv::namedWindow("Webcam", cv::WINDOW_AUTOSIZE);
// this will contain the image from the webcam
cv::Mat frame;
// display the frame until you press a key
while (1) {
// 100ms. between inference
int64_t next_frame = (int64_t)(ei_read_timer_ms() + 100);
// capture the next frame from the webcam
if(!vcap.read(frame)) {
std::cout << "No frame" << std::endl;
cv::waitKey();
cv::imshow("Webcam", frame);
if (cv::waitKey(1) >= 0) break;
cv::Mat cropped;
resize_and_crop(&frame, &cropped);
size_t feature_ix = 0;
for (int rx = 0; rx < (int)cropped.rows; rx++) {
for (int cx = 0; cx < (int)cropped.cols; cx++) {
cv::Vec3b pixel = cropped.at<cv::Vec3b>(rx, cx);
uint8_t b = pixel.val[0];
uint8_t g = pixel.val[1];
uint8_t r = pixel.val[2];
features[feature_ix++] = (r << 16) + (g << 8) + b;
ei_impulse_result_t result;
// construct a signal from the features buffer
signal_t signal;
numpy::signal_from_buffer(features, EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT, &signal);
// and run the classifier
EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false);
if (res != 0) {
printf("ERR: Failed to run classifier (%d)\n", res);
return 1;
printf("Classification result (%d ms.):\n", result.timing.dsp + result.timing.classification);
bool found_bb = false;
for (size_t ix = 0; ix < EI_CLASSIFIER_OBJECT_DETECTION_COUNT; ix++) {
if (bb.value == 0) {
continue;
found_bb = true;
printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
if (!found_bb) {
printf(" no objects found\n");
#else
printf("%d ms. ", result.timing.dsp + result.timing.classification);
printf("%s: %.05f", result.classification[ix].label, result.classification[ix].value);
printf(", ");
printf("\n");
#endif
int64_t sleep_ms = next_frame > (int64_t)ei_read_timer_ms() ? next_frame - (int64_t)ei_read_timer_ms() : 0;
if (sleep_ms > 0) {
usleep(sleep_ms * 1000);
return 0;
#error "Invalid model for current sensor."
#endif
