I am using the sample project with code from record.ino. I can speak and listen to my voice when I use the microphonedata0 variable in startRec() function in loop. But I don’t figure out how to use sampleBuffer. Following is my code. If someone can please help me figure out how can I get the code working on M2Core2. Thanks
#define EIDSP_QUANTIZE_FILTERBANK 0
#include <Tutorial_Responding_to_your_voice_inferencing.h>
#include <M5Core2.h>
#include <driver/i2s.h>
#define CONFIG_I2S_BCK_PIN 12
#define CONFIG_I2S_LRCK_PIN 0
#define CONFIG_I2S_DATA_PIN 2
#define CONFIG_I2S_DATA_IN_PIN 34
#define Speak_I2S_NUMBER I2S_NUM_0
#define MODE_MIC 0
#define MODE_SPK 1
#define DATA_SIZE 1024
//uint8_t microphonedata0[1024 * 50];
int data_offset = 0;
/** Audio buffers, pointers and selectors */
typedef struct {
int16_t *buffer;
uint8_t buf_ready;
uint32_t buf_count;
uint32_t n_samples;
} inference_t;
static inference_t inference;
static signed short sampleBuffer[2048];
bool InitI2SSpeakOrMic(int mode)
esp_err_t err = ESP_OK;
i2s_driver_uninstall(Speak_I2S_NUMBER);
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_MASTER),
.sample_rate = 44100,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // is fixed at 12bit, stereo, MSB
.channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
.communication_format = I2S_COMM_FORMAT_I2S,
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 2,
.dma_buf_len = 128,
if (mode == MODE_MIC)
i2s_config.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_PDM);
else
i2s_config.mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_TX);
i2s_config.use_apll = false;
i2s_config.tx_desc_auto_clear = true;
err += i2s_driver_install(Speak_I2S_NUMBER, &i2s_config, 0, NULL);
i2s_pin_config_t tx_pin_config;
tx_pin_config.bck_io_num = CONFIG_I2S_BCK_PIN;
tx_pin_config.ws_io_num = CONFIG_I2S_LRCK_PIN;
tx_pin_config.data_out_num = CONFIG_I2S_DATA_PIN;
tx_pin_config.data_in_num = CONFIG_I2S_DATA_IN_PIN;
err += i2s_set_pin(Speak_I2S_NUMBER, &tx_pin_config);
err += i2s_set_clk(Speak_I2S_NUMBER, 44100, I2S_BITS_PER_SAMPLE_16BIT, I2S_CHANNEL_MONO);
return true;
void DisplayInit(void)
M5.Lcd.fillScreen(WHITE);
M5.Lcd.setTextColor(BLACK);
M5.Lcd.setTextSize(2);
void setup() {
//Serial.begin(115200);
M5.begin(true, true, true, true);
M5.Axp.SetSpkEnable(true);
DisplayInit();
M5.Lcd.setTextColor(RED);
M5.Lcd.setCursor(10, 10);
M5.Lcd.printf("Recorder!");
M5.Lcd.setCursor(10, 26);
M5.Lcd.printf("Edge Impulse Demo");
delay(100);
ei_printf("\tInterval: %.2f ms.\n", (float)EI_CLASSIFIER_INTERVAL_MS);
ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
M5.Lcd.setCursor(10, 56);
M5.Lcd.printf("Inferencing setup");
if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
ei_printf("ERR: Failed to setup audio sampling\r\n");
return;
void loop() {
ei_printf("Starting inferencing in 2 seconds...\n");
delay(2000);
ei_printf("Recording...\n");
if (!m) {
return;
ei_printf("Recording done\n");
signal_t signal;
signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
signal.get_data = µphone_audio_signal_get_data;
EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
if (r != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
M5.Lcd.setCursor(10, 116);
M5.Lcd.printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
ei_printf(": \n");
M5.Lcd.printf("anomaly score: %.3f\n", result.anomaly);
#endif
inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
if(inference.buffer == NULL) {
return false;
inference.buf_count = 0;
inference.n_samples = n_samples;
inference.buf_ready = 0;
pdm_data_ready_inference_callback();
microphone_inference_end();
return true;
static void pdm_data_ready_inference_callback(void)
// read into the sample buffer
int bytesRead = startRec();
if (inference.buf_ready == 0) {
for(int i = 0; i < bytesRead>>1; i++) {
inference.buffer[inference.buf_count++] = sampleBuffer[i];
if(inference.buf_count >= inference.n_samples) {
inference.buf_ready = 1;
break;
static void microphone_inference_end(void)
free(inference.buffer);
int startRec(){
TouchPoint_t pos= M5.Touch.getPressPoint();
size_t byte_read;
M5.Lcd.setCursor(10, 76);
M5.Lcd.printf("Starting recording...!");
M5.Axp.SetLDOEnable(3,true);
delay(1000);
M5.Axp.SetLDOEnable(3,false);
data_offset = 0;
InitI2SSpeakOrMic(MODE_MIC);
if(M5.Touch.ispressed() == true){
i2s_read(Speak_I2S_NUMBER, (char *)(sampleBuffer), DATA_SIZE, &byte_read, (100 / portTICK_RATE_MS));
delay(1000);
/*while(1){
i2s_read(Speak_I2S_NUMBER, (char *)(microphonedata0 + data_offset), DATA_SIZE, &byte_read, (100 / portTICK_RATE_MS));
data_offset += 1024;
if(data_offset == 1024 * 50 || M5.Touch.ispressed() != true)
break;
size_t bytes_written;
InitI2SSpeakOrMic(MODE_SPK);
i2s_write(Speak_I2S_NUMBER, sampleBuffer, data_offset, &bytes_written, portMAX_DELAY);
M5.Lcd.setCursor(10, 96);
M5.Lcd.printf("Ending recording...!");
return byte_read;
while(inference.buf_ready == 0) {
delay(10);
return true;
numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
