First of all, thanks for the release of the official ESP32 firmware.
I have tried compiling (with a few modifications as suggested in the README) and running the firmware on an ESP32-CAM. It worked, but I can’t use the edge-impulse-daemon with my ESP32 device. Here are the full logs from the daemon:
[SER] Connecting to /dev/tty.usbserial-1420
[SER] Unhandled configuration option snapshot ===== inference ======
[SER] Unhandled configuration option snapshot sensor 1
[SER] Unhandled configuration option snapshot model type classification
[SER] Retrieved configuration
[SER] Device is running AT command version 1.7.0
[SER] Unsupported AT command version running on this device. Supported version is 1.6.x and lower, but found 1.7.0.
[SER] Update the Edge Impulse CLI tools (via `npm update edge-impulse-cli -g`) to continue.
I have the latest version of the CLI (from GitHub) installed. Is there anything that I can do to make it work or should I wait for the next edge-impulse-cli release?
Thanks!
