Hi
I have been following the tutorial here to set up CubeMX for compiling my own firmware for an STM32 target (I’m using the same board as the tutorial, the B-L475E-IOT01A).
I’ve created a new project in CubeMX, converted to C++ (and renamed main.c to main.cpp) and ensured everything compiled ok and runs on the target (I’m using STM32CubeIDE). However after adding the CMSIS-PACK to the project it will no longer compile.
I also noticed that in step 11 of the tutorial it states that I should add the library by hand in the G++ Linker section of the project’s properties, though I only have an option for ‘GCC Linker’, not G++:
When compiling the project (with the library reference added to the GCC Linker section in Eclipse) I get errors with multiple definitions (of ‘_sbrk’ in ‘/Debug/…/Src/sysmem.c’) and ‘Default_Handler’ (in ‘/Debug/…/Startup/startup_stm32l475xx.s’).
Has anyone come across this? Any help would be appreciated!
Angus
