Run Test fails as zip file not uploaded
When trying to run test on labelled .wav data the test fails with
unzip: cannot find or open /data/ei-user-cdn/user/195261/project/418568/app-testing/2c02b24ab67b0848d072814046b9c6d68913af91d848298be5341d5ae351a7de.zip, /data/ei-user-cdn/user/195261/project/418568/app-testing/2c02b24ab67b0848d072814046b9c6d68913af91d848298be5341d5ae351a7de.zip.zip or /data/ei-user-cdn/user/195261/project/418568/app-testing/2c02b24ab67b0848d072814046b9c6d68913af91d848298be5341d5ae351a7de.zip.ZIP.
Actually the screen flashes Uploading, but still fails with above error msg
drmpf-project-1
Attempting to test model on real test data labelled in audacity
Hello @drmpf,
Unfortunately, you cannot upload .zip files.
You can upload them directly as .wav in your test set.
See the supported files format: https://docs.edgeimpulse.com/reference/data-ingestion/ingestion-api
The instructions for the Performance Calibration step says otherwise
Hello @drmpf,
Oh sorry I did not understand you were referring to the Performance Calibration feature.
Let me check with our core engineering and come back to you.
Hello @drmpf,
Also, could you share your .zip file so we can have a closer look please?
Maybe there is something wrong with the format.
Now getting
Creating job... OK (ID: 20867172)
Scheduling job in cluster...
Container image pulled!
Job started
Job started
Job failed (see above)
with this zip file (which I cannot upload here)
https://www.forward.com.au/notes/rainCheck.zip
